View Full Version : > Mid-Pipe Question <
TeeCizzle
03-10-2008, 07:23 PM
Aight so...Just want to see other peoples opinions or thoughts.
I have the DC Sport axle-back exhaust...and I have an AutoMagic! :love:
I heard if I change my mid-pipe to a different one..It wont sound Raspy and NO CEL..is that correct??
The stock mid-pipe has a secondary cat too?......whats the diameter?
if so..its ok to remove it??
Aight...well Thanks!
tCmaniak
03-10-2008, 07:30 PM
as far as swapping your midpipe, as long as you dont have an aftermarket header, your probably gonna be ok. Yes the stock midpipe has a second cat and it WILL be removed if you get a mid-pipe. just put a high flow cat on your mid pipe to replace the secondary and your good to go.
caveman
03-10-2008, 07:43 PM
The diameter ranges from 2.0x to 2.25, with a secondary cat, and a resonator....and there is no problem deleting those as far as CELs are concerned because the last sensor is the o2 on the s-pipe...
BlckdOutTC
03-11-2008, 03:33 AM
^^x2. as long as the stock header is in you'll be fine
