xB fog light alternatives
Seeing as the stock foglights do not really help at all driving at night eevn though they do look cool I have bad eyes and I am looking for an alternative to the stock fogs that look good and will help me see at night, I would also like something that is fairly easy to install.
can some people post pictures of your alternative foglight setup, where you got them and how much you paid, I really liked these https://www.scionlife.com/forums/viewtopic.php?t=34645 but I am not sure which ones they are or where to find them. They look like it would be hard to mount them to the mesh stock grill down below.[/url]
Originally Posted by BoomBox757
have you thought about HIDs if you ahve trouble seeing
The PIAA bulbs are actually worse than stock, I'm sorry to say. http://www.overboost.com/story.asp?id=102
If you want some auxillary driving lights, I suggest buying a pair of Hella Micro DE in the driving light pattern NOT the flood beam pattern. Unlike the cheap crap you'll find in walmart, these lights actually perform. If you have the money, you can even get the driving lights in HID.
http://www.rallylights.com/hella/Micro_DE.asp
wow man that is a great read, it is funny to find that everything is just in our heads about buying the expensive bulbs. I can say that the PIAA are 'whiter' when I drive but obviously they do not out-perform like I thought.
Unfortunately I do now have $700 to spend on running lights
so I am thinking the JDM stock ones may be my next best bet.
Driving lights have to be mounted at or above the headlights to be effective. Foglights have to be mounted as low and close to the ground to be effective. If I were to mount driving lights on an xB, I would try mount them right before the grill. Since that is a larger opening, I believe the Bosch Sport Compact 100s would be an excellent choice.
If you are serious about adding driving lights, go ask a question to Daniel Stern. He is a photometric engineer and runs a automotive lighting supply company. He can tell you more about the various options you have for your xB and can import the European stuff that isn't readily available in the US. http://www.danielsternlighting.com/
noway they would be so bright it would be awesome!!!!
I don't know were to get them though, the highest I've found are 10000
hey that is my box in the link . the driving light's are BRIGHT , i have people flash there light,s at me to turn them off. now don't laugh but they are from WAL MART and cheap , they are called PRO BURNER'S cost about $20.00 . I ordered the relay & switch that come with the stock driving light kit, the switch & relay cost about $80.00 from the dealer, then i wired the light's in to the plug's under the hood, so they go off when you switch to high beam's
ohh no I didn't, so what tells you if its brighter?
I ment as far as the lumen goes?
