Spark Question For Turbo Setup
Old Mar 10, 2008 | 08:43 PM
trrbo_tc's Avatar
Default Spark Question For Turbo Setup
Hi guys,
I'm running a 16G Turbo with 440cc injectors pushing 7PSI
my car hiccups and sputters under partial throttle, afr's are fine usually under partial throttle,
i purchase some NGK v-power plugs 2 step colder copper tip
anyone know what the gap should be set at ?
here is the question ...
on your turbo setup, what spark plugs do you use and what do you have them gapped at ?
Old Mar 10, 2008 | 08:54 PM
Guru's Avatar
I use NGK BKR 7 EIX's
Iridium, pregapped already at around 0.34
If it hiccups and sputters under part throttle and not under full throttle than either you have a tuning issue or you are going in between closed loop and open loop and the transition has not been smoothed out.
Old Mar 10, 2008 | 08:58 PM
kikcaffine's Avatar
Old Mar 11, 2008 | 02:23 PM
THansenite's Avatar
I thought we were only supposed to use iridium plugs in our cars?
Old Mar 11, 2008 | 06:01 PM
Mr_Meaty's Avatar
We are.
I'm using the same as guru except 2 steps, not 1, so they are the 8s, not the 7s.
Old Mar 11, 2008 | 06:15 PM
tcengel's Avatar
You can use Copper or iridium plugs, either will work just fine. The gap has nothing to do with your partial throttle issues. You are running lean and your timing is advancing and retarding, that's why you feel the surging. Get a block box from Dezod or get a tune.
Old Mar 11, 2008 | 07:31 PM
trrbo_tc's Avatar
okay .. so im cool to leave the copper tip plugs in then right ?
i figured that much because before i had boost i was running bosch platinum tips.
Old Mar 11, 2008 | 11:28 PM
Mr_Meaty's Avatar
Yeah...but he said his AFRs are fine.
Whate exactly are your AFRs at?
Old Mar 12, 2008 | 04:01 AM
Crippie's Avatar
1UP Crew
at what hp should you colder plugs? is it for every 100 its a step colder?
Old Mar 12, 2008 | 05:10 AM
Mr_Meaty's Avatar
every ADDITIONAL 100, i beleive.
I just got 2 steps just in case.
bootlgr
Jan 26, 2016 01:22 AM
my06tc
Jun 25, 2015 12:18 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
