View Full Version : Who says I need to tune first? Poll
Blue_TC_Man 03-12-2008, 06:05 PM So I have a show comming up the 22nd with drag events, and I cant afford dyno tune but I can afford to have the bottle filled, tell me if you think I should wait till I can get my A/F dialed in on a dyno or will I be fine running a 75 shot a few times before I tune?
op07tc 03-12-2008, 06:19 PM 75 shot is risky on the stock block with no tuning. i'd say a 50 shot would be fine untuned, but with a 75 it would be a good idea. Not to mention that dyno time and expense could save you thousands more as opposed to blowing the motor. just my $.02...
Blue_TC_Man 03-12-2008, 06:53 PM well its not the block Im scared of if can handle 8psi a 75 wet shot is nothing, im worried about the ECU not adjusting my A/F well enough and leaning out
bkuhl 03-12-2008, 08:20 PM tuuuuuuuuuuuuuuuuuuuune!
draxcaliber 03-12-2008, 08:25 PM tune first, or rebuild later...
dudebrah 03-12-2008, 08:27 PM As the old saying goes, "Better safe than sorry." And in this case "sorry" would be a very expensive mistake. In theory, yea you might get away with a few runs w/out a problem. But then again, you might not. If you really are strapped for cash, borrow some from your mom or dad or someone. You are going to have to get it tuned eventually, better to do it before you possibly cause damage to your engine.
Blue_TC_Man 03-12-2008, 08:29 PM yeah, i just wish I knew how well the computer adapted the A/F ratio
SVicksTC 03-12-2008, 08:33 PM Like the others said, why spend all this money on your car just to throw it away for a couple runs... Take the time and get your car tuned to run more safe on a 75 shot....
scion_thC 03-12-2008, 09:25 PM plus if you do run with no nitrous first you can get a good base line.
good luck
BuddhasTC 03-13-2008, 01:24 AM tune first, or rebuild later...
took the words right out of my mouth
Blue_TC_Man 03-13-2008, 01:42 AM well its still a toss up atm i have its really gonna come down to what my A/F is now at WOT after the colder plugs
Mightygnu 03-13-2008, 01:44 AM Go run it, and then tell us that you should've tuned it.
BuddhasTC 03-13-2008, 08:27 AM ummm...the colder plugs are not gonna change your a/f ratio
bkuhl 03-13-2008, 03:18 PM ummm...the colder plugs are not gonna change your a/f ratio
sure they will. he'll be taking in lots of air with that new hole in his block after he's done running.
tCyoung1 03-13-2008, 04:21 PM its not just the A/F ratio you need to worry about, you also need to pay close attention to the cars timing. when i ran my 75 shot w/o tuning my car was all over the place. i would run ungodly lean at 4500 then run way to rich up top. I tell you now its gonna take a mixture of fuel jet sizing and fuel mapping. i currently use the Ultimate but will be switching to the F/IC soon. I you want i'll pm you the person you need to talk to picking one up.
tCyoung1 03-13-2008, 04:30 PM Blue TC Man you have a pm
Blue_TC_Man 03-13-2008, 04:37 PM ummm...the colder plugs are not gonna change your a/f ratio
wow Im going crazy I meant timing I know it wont alter it much but hopfully enough
and 75 shot i know I dont need a fuel engine management system timing doesnt need to be taken back more than two or 3 degrees and I can do that off the crank, other than dialing in my A/F so im not leaning out is all I have to do, which from some dynos Ive seen im not to worried about at this point
bobbystc88 03-13-2008, 05:30 PM better safe then sorry. Last thing you need to do is blow your engine
bobbystc88 03-13-2008, 05:31 PM better safe then sorry. Last thing you need to do is blow your engine
tCyoung1 03-13-2008, 05:33 PM and 75 shot i know I dont need a fuel engine management system timing doesnt need to be taken back more than two or 3 degrees and I can do that off the crank, other than dialing in my A/F so im not leaning out is all I have to do, which from some dynos Ive seen im not to worried about at this point
you have to remember that everything in this car is controlled by the ecu so you won't be able to get away with that like you would on older honda motors. also with this ecu always adjusting everything to run the A/F and timing that toyota programmed. your a/f ratio might be all out of wack like mine was. so both are important.
Blue_TC_Man 03-13-2008, 05:36 PM and 75 shot i know I dont need a fuel engine management system timing doesnt need to be taken back more than two or 3 degrees and I can do that off the crank, other than dialing in my A/F so im not leaning out is all I have to do, which from some dynos Ive seen im not to worried about at this point
well I have the service guys at my toyta dealership retarding the timing for me, as for A/F im just going to play with the jetting probably do a 50shot nitrous jet and a 75shot fuel jet (.030/.024) since our stock A/F is so lean that should even me out pretty well
tCyoung1 03-13-2008, 05:49 PM i wouldn't run that much fuel you should be fine on the 50 shot fuel jet (.017). i did run the .030 n20 jet with a .019 jet i was running pretty rich too. just see how your car reacts to to the .030 n20 jet and .017 fuel jet and go from there.
Blue_TC_Man 03-13-2008, 05:53 PM well i have NOS jets so my 50 shot fuel is a .022, its a test and tune event so I'll be playing with it, i'll get vids an time slips for sure,
tCyoung1 03-13-2008, 05:58 PM ok so they are a little different from my zex jets.
yeah i'm going to midnight madness on friday only thing that sucks are that my drag radials are done so i'll be making runs on my 18's gram lights. just don't spray out of first if your on street tires. i have mine activate at 4200 rpm
Blue_TC_Man 03-13-2008, 06:00 PM yeah mines 3-6 k spraying 2-4th
tCyoung1 03-13-2008, 06:03 PM i cut mine off at 6400 but most of the time i'll shift at 6k. i just run it to about 6500 in 3rd gear
Blue_TC_Man 03-13-2008, 06:23 PM are we even still in our power band that high?
bkuhl 03-13-2008, 06:27 PM you're still inducing power with the spray
Blue_TC_Man 03-13-2008, 06:38 PM you're still inducing power with the spray
yeah but if your not making good engine power its just wasteing spray when you could shift and see 60+ more HP
tCyoung1 03-14-2008, 06:24 PM my redline is set at 6700 rpm but i never rev it that high. its just to keep me from shifting near the trap on the 1/8
Blue_TC_Man 03-14-2008, 06:48 PM got ya
