*DIY* Headlight removal/install
Old Mar 13, 2008 | 05:48 AM
Raceking924's Avatar
Default *DIY* Headlight removal/install
so, i was searching around and never found a diy for a headlight install. after no such luck i decided to wing it and do it on trial/error, and in the process i took pictures. hope it helps somebody. the pictures are pretty generic, but i have circled the areas im talking about. NOTE: steps are for drivers side of veh, but are the same for the passenger side. if anybody has questions feel free to ask. only tools that are needed are metric sockets and 1 small screwdrivers.
before!
i decided i was going to do the diy after i did the grille, so im assuming you can get the grille off, if not its 3 black snap tabs, you just need to pop them off with a small screw driver. now, on the picture: theres 2 snap tabs and 1 bolt that needs to be removed on the bumper. theres also 2 bolts ontop of the headlights that may be removed too.
2 more black snap tabs, and 2 nuts holding the outter part of the dust guard that need to be removed.
note, unless your box is dropped, you do not need to raise it. theres (i believe) 7 finger looking pieces that stick out on the bottom, remove the nuts that are on them. also, on the outside of the bumper there is a clip that can be rotated to let the edge of the bumper come off.
ok, i had a frustrating time with this part. but after calming down, the bumper SLIDES forward from under the headlight. after that, theres 2 nuts on the outside of the lights that need to be removed. at this point, the headlight should be able to come off, minus the bulb that is still attached. simply turn the bulb harness and it should pop right out.
you should be left with the headlight out and the bumper off. now, just put the new headlight in and repeat steps backward.
and the final product.
total time was about 1.5 hours, not knowing what i was doing.
good luck guys! just holler if you got any questions.
jay
Old Mar 13, 2008 | 07:02 AM
IH8ONYU's Avatar
nice write up! good pics!
1 thing to note in addition...
1st if all you are doing is swapping headlights, the bumper does not need to be completely removed, only the "top" half of the bumper needs to be removed - the part directly under the headlights, in your #3 pic, only the bolt that screws into the bumper - the one furthest to the left in your pic, need be removed, not the additional push fastners that attach the dust cover. As noted above, the bumper slides out from under the lightd allowing access to the lower headlight screws. this will not stress the bumper as you only need to pull it back a touch to gain access to the lower HL mount locations.
if you are doing other mods at the same time, lower grills, louder horns, radiator swap, then remove the whole bumper.
^---the lights look sick!
Old Mar 13, 2008 | 07:51 AM
jallamas's Avatar
Nice info!
Thx
John
Old Mar 14, 2008 | 01:06 AM
exactly right, thats actually how i did it, just make sure that if your going to do that, you put something soft under where your working just incase the bumper slides out of place and hits the ground. i ended up just letting mine lay on the ground, with the fingers still attached by the plastic snap tabs, i just put carpet where it contacts the ground so it didnt get scratched.
and thanks on the props, they look better with my new grille too. and im working on a piece that fits evenly in the middle with a little piece of fiberglass and some bondo.. and elbow grease. we will see howi t looks.
jallamas- thanks.
and im gong to check to see if anybody has done a writeup on springs. i didnt take pix but i can do some lenghty written steps.
thanks again guys.
jay
Old Mar 14, 2008 | 01:46 AM
Metro273's Avatar
Thanks for the DIY. I need to remove my headlights so that I can clear the corners.
Old Mar 14, 2008 | 10:17 PM
IH8ONYU's Avatar
there is also a couple "clear corners" write ups in the Tech section that tells you what to do once your headlights are out, either by bake method - if you want to black out the inside of the housing, or the reflector crush method. both require the headlights to be removed.
Old Mar 14, 2008 | 10:34 PM
burstaneurysm's Avatar
I'd highly recommend doing the oven method for clearing. It's a piece of cake. The screwdriver method is a bit too risky for me.
Old Mar 14, 2008 | 10:47 PM
jallamas's Avatar
Nice info! Really!
Thx
John
Old Apr 10, 2009 | 12:30 AM
jallamas's Avatar
Old Apr 10, 2009 | 12:48 AM
Skuff_Box's Avatar
wow another 1 year bump FTW yes!!!!!!
Old Apr 10, 2009 | 12:55 AM
jallamas's Avatar
Old Apr 10, 2009 | 01:50 AM
Sigh.
Old Apr 14, 2009 | 02:41 AM
jallamas's Avatar
Sigh.
Ok since I bumped this post I do have a question before I install these finally. If I decide to go HID what is the best and cheapest way to go. Also is this safe for the wiring of the headlights to run HID.
Sigh
John
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
olyellr
Sep 28, 2015 10:32 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
DannyBoy65
Sep 21, 2015 06:23 PM
