View Full Version : Interior trim
Whisper
11-19-2004, 05:51 PM
does anyone know how to remove the vent direction thingies?? i am painting the trim inside my box and do not konw how to get those out. One more thing any help on how to remove the peices in the doors with the window controls? thanks for any help any one can give
hotbox05
11-19-2004, 05:55 PM
the window controls pop out if u pry fron the front of the switch. the middle vents u have to take the console apart and then pop them out. dont know about the outer most vents tho
crab_nasty
11-20-2004, 11:26 PM
On the middle dash around the radio the vents pop out from the back by just applying enough pressure to open the plastic up to remove it. The vents on the outter side to just take the whole dash of and remove them the same way. On the forum on how to install LED's in your vents, there is a good walk through on the dash removal.
Good luck
TheIcon
11-22-2004, 11:24 AM
I don't believe the window controls pop out. YOu have to take the door off and remove a screw and take the wire harness off then they come off. Trying to pry them off I believe will break them. (If i remember correctly)
LowProMofo
11-22-2004, 12:22 PM
Nope no screws. I took them out the other week. Pry at the top only. It's on there with a clip.
