View Full Version : Changed Scion Premium radio graphic display to red
Thumps
03-15-2008, 03:25 AM
Been changing my dash LED's to red and figured out a way to change the '08 premium radio display from white to red:
http://www.speakeasy.org/~dlp/xb/redradio.jpg
Will post up a little DIY on it shortly.
(I have a 1st gen xB that I updated with the '08 premium radio)
FlyinLow
03-15-2008, 04:29 AM
Great work! I just got mine and was thinking about changing it to blue. I can't wait to see the diy.
Where the LED's PLCC-2's?
08xB714
03-15-2008, 06:37 AM
read manual page #33.
Whispaz
03-15-2008, 12:32 PM
looks orange in the pic but nice job. i was going to ask what gauges you had until i read that you have a gen1 :D
Thumps
03-15-2008, 12:48 PM
Yep, that will let you change the color of the BUTTONS to blue, but the DISPLAY will still be white.
If you want to change the color of your display to RED, read on.
Step 1: Remove radio from car (I assume that's well covered elsewhere)
Step 2: Remove 2 screws on the edge of the faceplate, and then undo all the clips holding the faceplate on. I ended up using a bunch of thin plastic package strapping pieces as shims underneath the clips to simultaneously hold them open so I could slide the cover off.
http://www.speakeasy.org/~dlp/xb/redradio01.jpg
Step 3: Once you have the front faceplate loose, you'll see an electronic ribbon connector that connects the faceplate to the body side. On the body side connection, slide the two brown tabs up and then carefully pull the ribbon out of the connector
http://www.speakeasy.org/~dlp/xb/redradio02.jpg
Step 4: The faceplate is now free of the body. Put it face down (I recommend putting a towel or something to avoid scratching the front of the face) and remove the screws circled in red. Watch out for the screw numbered 7, it holds a thin metal electrical contact that will come loose when you remove the screw - don't drop it, and note how it goes back on.
http://www.speakeasy.org/~dlp/xb/redradio03.jpg
Step 4: Carefully pull out the circuit board from the face plate and put it aside. You know have just the front fascia/buttons of the face plate left. *DO NOT* turn the fascia upside down, all the buttons will fall out and you'll curse and spend an hour looking for where they scattered on the floor, and then have to painstakingly figure out where they all go back in. Or so I heard.
http://www.speakeasy.org/~dlp/xb/redradio05.jpg
Step 5: Cut a piece of Rubylith Red Mask Film (more on that stuff below) to fit in the fascia opening for the LCD display.
http://www.speakeasy.org/~dlp/xb/redradio04.jpg
Step 6: Make sure your piece of Rubylith film is completely free of dust and fingerprints (I recommend wiping it down with microfiber, and then only handling it by the edges), and then drop it into place in the fascia opening:
http://www.speakeasy.org/~dlp/xb/redradio06.jpg
Step 7: Put the circuit board back in, replace the screws (remember the metal piece on screw #7), reconnect the ribbon cable, snap the face plate back on the body, put the two faceplate edge screws back in, re-install the radio
Step 8: Enjoy your radio with a RED display.
So, what is this Rubylith film stuff anyway? It's basically a thin sheet of transparent plastic, red colored. It's mainly used for lights and instrument panels in situations where you want to be able to maintain night vision/low light sensitivity with your eyes.
You can get it from
http://www.scopestuff.com
for about $12 for 2 huge sheets, much more than you need.
Or you can PM me, and I'll send you a chunk big enough to put in your radio for $3.
I happen to have a little left over.... :lalala:
http://www.speakeasy.org/~dlp/xb/redradio07.jpg
Thumps
03-15-2008, 12:51 PM
The display in person actually looks deep red, not orange. I think the display was reflecting some of my overhead garage light when I took the pic.
The buttons are still amber though - changing them from amber to red is going to involve actually changing the LED's on the faceplate, I think. I took at look at them when I had the faceplate off - They're tiny, and there's a lot of them, so I think I may send it off to that garage12177 guy, assuming he ever answers his emails....
FlyinLow
03-15-2008, 01:45 PM
PL_Ramses
03-15-2008, 02:44 PM
i want to change the clock to blue or white i hate the orange clock. Can this be done?
buzzwyzr
04-16-2008, 06:16 PM
Thanks for the write up Thumps. I'll be doing this to HU as soon as my blue film gets here.
FYI: For anyone looking for other colors of film, I found this: http://www.decalfx.com/blue_headlight_film.html
Probably not the quality of the Rubylith that thumps is using, but it should work.
FlyinLow
04-16-2008, 06:24 PM
Hey PL_Ramses,
You can change the LED's out quite easily. Look here:
http://www.scionlife.com/forums/viewtopic.php?t=187351
Good luck on the swap!
buzzwyzr
04-22-2008, 03:46 AM
Here's the HU with a blue display.
Before change with stock display:
http://i97.photobucket.com/albums/l202/buzzwyzr/Radioblue.jpg
After change with blue display.
http://i97.photobucket.com/albums/l202/buzzwyzr/IMG_1107.jpg
http://i97.photobucket.com/albums/l202/buzzwyzr/IMG_1108.jpg
http://i97.photobucket.com/albums/l202/buzzwyzr/IMG_1109.jpg
sparcshinobi
04-29-2008, 11:51 PM
nice
Zsanz
04-30-2008, 12:05 AM
o i love that song
FlyinLow
04-30-2008, 07:44 PM
That looks hot! What size of LED's did you use?
