GROUND CLEARANCE
Old Mar 16, 2008 | 09:09 AM
scionora09's Avatar
Default GROUND CLEARANCE
Okay. . .so im trying to get an idea on the effects of lowering my car and ground clearance (and how low I should go). . . this may sound lame, but how far off the ground is your car? this measurement is from the ground to the bottom of your bumper. Please include these specs:
1. Ground Clearance (from ground to bumper)
2. Body kit, or lip kit, or no kit
3. Lowering Springs
4. Rim size (including tires)
I already have 19's (225/35/19). . .I am looking at getting the viniati lip kit. . I just want to see how much I should lower it to get about a 6" gap between the ground and the lip kit. . . THANKS!!!!
Old Mar 16, 2008 | 09:17 AM
lalanrich's Avatar
I lowered my car 1.5" and as a daily driver I would not go much lower. I am careful around speed bumps and steep driveways I take at a angle just to make sure I don't hit.
Old Mar 16, 2008 | 09:22 AM
lalanrich's Avatar
17" stock wheels, no lip or body kit, H&R springs, Toyo Proxies 4 for tires.
Old Mar 16, 2008 | 09:31 AM
theblue's Avatar
I don't know my exact clearance, but I'm on hotchkis and 18's with the oem lipkit. I scrape everywhere I go, but usually its just a slight scrape on the bottom that no one will ever see. The drop looks really nice though.
Old Mar 16, 2008 | 02:29 PM
Luc1f3r's Avatar
AIT Fabulous front bumper
Tein sTechs
19" rims - 225/35/19
3.25" ground clearance and i tuck every tire
Old Mar 16, 2008 | 07:39 PM
HaYnSktC's Avatar
im dropped on hotchkis with the stock 17s right now and i have the rs1 lip kit..no problems scraping really..just gotta watch where your driving.only time i "scraped" was cuz since the snow/ice is starting to melt there are a bunch of bumps of ice
Old Mar 16, 2008 | 07:42 PM
scionora09's Avatar
How much is your clearance? I'm thinking about dropping it about 1.5 inches. . . . .
Tein sTechs
Dang. . . thats crazy low!! how often do you scrape?
Okay. . .so I know not to go that low.. . .
Old Mar 16, 2008 | 07:50 PM
Luc1f3r's Avatar
i really dont, usually only when im on the interstate and dont slow down for bumps and things like that. other then that, you just have to know how to drive, how to take turns, and how to take hills/ entryways/ railroad tracks.
i wouldnt change the set up i have.
Old Mar 16, 2008 | 08:08 PM
AcidDrop's Avatar
if you really are debating it cause of the scraping then just know that it will happen a few times depending on how you drive. TRD are a good set of springs to lower it on but if you want it just a tab lower then go with Tein H-Tech and it will give it a good drop without having to worry about scrapinng much as to what i said about your driving.
Old Mar 16, 2008 | 08:09 PM
scionora09's Avatar
Do you rub frequently?
Old Mar 16, 2008 | 08:16 PM
curtislo9's Avatar
Tein H-Techs will be the best for your situation. They are not dumped, but they make it so that you are noticeably lower. I have not scraped. Springs are great. Go with the H-Techs. Talk to JSCSpeed on this site to get a great deal!
Old Mar 16, 2008 | 08:21 PM
Headsplitter's Avatar
x2 H-Techs are the business.
Old Mar 16, 2008 | 09:04 PM
curtislo9's Avatar
Plus with H-techs, you can get some big wide tires/rims later on and not worry as much about rubbing.
Old Mar 16, 2008 | 09:15 PM
scionora09's Avatar
why do the the H-tech springs lower the front more than the rear? and are you sure I won't rub with 19x8.5 rims?!
Old Mar 16, 2008 | 09:38 PM
Luc1f3r's Avatar
yes i rub, i removed my inner fenders and still have rubbing on high speed turns.
Old Mar 16, 2008 | 09:53 PM
scionora09's Avatar
Then why do it if you know that you rub? isn't that dangerous?
Old Mar 16, 2008 | 10:45 PM
Luc1f3r's Avatar
some turns are just fun to go fast on! but now that that body kit is on, i keep it slow. so i only rub if i go through a dip in the road too fast. (dest happen often.)
Old Mar 16, 2008 | 11:21 PM
scionora09's Avatar
interesting. . so is it just your front that rubs?
Old Mar 17, 2008 | 12:03 AM
Luc1f3r's Avatar
yep, rears will rub to if i have people in there (250+ lbs of stereo) needless to say, my car is a 2 seater lol.
Old Mar 17, 2008 | 12:30 AM
scionora09's Avatar
HAHAHA. . . .so then why is the front lowered more than the rear?!
