in need opinions /help/pics!
I will be picking up my 08 xb on monday.Ihave a ton of audio gear already heres what i have
4 alpinetype r 10s
2 mhrv vpower 850 mono amps
1 mhrv 950 4 channel vpower
front 6.5 type r components
rear 6.5 type r speakers
kenwood mp5032 single din HU
4 1.5 farad caps with digital read outs
35ft of 0 g power wire
25ft of 4 g power wire
20ft of 8 g power wire
4 dist.blocks
where can these amps go ?and as far as box goes I emailed Hexibase and am awaiting an email back anyone have any ideas or pics
this stuff is in my durango right now and is crazy clear and loud i am assuming itll be awesome in my Xb
4 alpinetype r 10s
4 dist.blocks
I don't really have any suggestions to throw out there... but if my memory serves 6.5s are too big for the rear speakers... you may need to get a little bit smaller pair.
But anyway, with 4 10s you're going to have a hell of a loud box. I have 1 alpine type R 12" and it's PLENTY.
This may be silly but do you want a stealth install, versatile install, competition install, SPL install, etc? Backseat stayin'? Display or storage? Better than what you currently have or same? How's the equipment installed in the Dodge?
There's a lots of room under the rear deck especially if you're willing to leave the spare tire behind. All the electronics could be put under there.
I would suggest a two-high stack up the C-pillars. That'll leave you enough room to haul things.
If you're hoping to not use fiberglass, consider removing the hatch floor, boxes, and spare tire. That'll give you an idea of what's available. Then you can build up from the bottom and allow things to fall where they want to. Fitting 4 10s will be difficult. Consider making cardboard boxes for the subs to see how much room they'll actually take up. It'll also help you quantify what you're willing and not willing to sacrifice for the sake of dbs.
I'm not sure I'd go with that many 10's... 2 12's would be better with a decent enclosure. Hit up www.hexibase.com and have him design you an enclosure. I had him design mine, and I couldn't be happier. My 2 12's will out beat 4 10's any day of the week.
ANd don't do capacitors. Upgrade your underhood battery and do the big 3. You should be fine. For an underhood battery, check out Powermaster's line. IIRC the 2700r will be pretty much a direct bolt in. I installed a secondary battery (Kinetik HC1800) under my passenger seat. I get no dimming at all.
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
02-29-2016 05:39 AM
CrowJenkins
10-09-2015 10:47 PM
crimson_sinn
09-25-2015 09:41 PM
