Change your radio startup message
Old Nov 20, 2004 | 03:16 AM
kyleb350's Avatar
Default Change your radio startup message
I wasn't able to find a previous topic on this, or I don't know how to use the search. Not sure if this works with the single disc stereo (I have the 6 disc).
The original startup message says "Scion" I believe. To change it, have the ignition switched to OFF. While holding down the A (Audio control) button, turn the key on. As this point, you'll see a flashing horizontal line below the text on the radio. I think you have 15 seconds to hold down the M (Mute button) and turn the car back off. Here, the radio will stay on, and you can customize the message. Use the volume up and down buttons to navigate through the characters. To advance to the next character, press the A button. To go back, press M. When you get to the end, the message will flash. You should just be able to leave it, and it will turn off. You can also hit the A button again I believe.
Old Nov 20, 2004 | 03:29 AM
UCSDPinoy's Avatar
Yah that trick works with the single CD player, i found out how to change it in the Manual
Old Nov 20, 2004 | 03:33 AM
hawkeye's Avatar
Only on 2005+ radios.
BTW- Repost:
https://www.scionlife.com/forums/vie...radio+greeting
Old Nov 20, 2004 | 03:36 AM
kyleb350's Avatar
God, I should read the manual
Old Nov 20, 2004 | 04:15 AM
maratk1's Avatar
Default Re: Change your radio startup message
I have the 6 disc and it works
Old Nov 20, 2004 | 06:49 PM
its_ikon's Avatar
BTW- Repost:
thanks
mrsocks
Jan 20, 2015 01:29 PM
mischman
Jan 14, 2015 06:07 PM
evolving_machine
Jan 13, 2015 08:04 PM
Strader
21
May 8, 2007 12:52 AM
eric_m
Jan 15, 2004 04:59 AM
