Sanding interior pieces
Hey, so I was wondering if anyone knew how to properly sand and paint the interior. I wanted to smooth out the rough parts on the door and paint it a flint mica color. If anyone has any suggestions or pictures of a finished product it would be very helpful!
Thanks[/img]
Thanks[/img]
I'm going to be painting my interior once I get the pieces, but from some other topics they suggest to use like a 600 grit sandpaper to scuff up the surface and then it should come out good, if it isn't smooth I would suggest to wetsand it with a much higher grit to smooth it all out.
Here are some of the topics I've been reading on:
https://www.scionlife.com/forums/viewtopic.php?t=215492
https://www.scionlife.com/forums/viewtopic.php?t=214334
Start with a high grit paper and sand, sand, sand. Gradually move to finer grit paper 'till your part is as smooth as you want.
If you're talking about the rice paper textured stuff, you may want to invest in a power sander.
I began with using a steel wool pad...that took too long, so I used 400 and 500 grit to remove the silver finish that was originally on there. Keep sanding until you get a black plastic surface, then use a higher grit like 1000 or 1500 to simply smooth what you sanded. After you have done that thoroughly clean the sanded pieces, remove any dust residue and begin painting.
I got sick of seeing the ugly shift guide that comes with the automatics. A lot of people that I have let borrow my car get confused and try to figure out where my clutch is. Not trying to pretend to be a stick shift...I just like it better with the shift boot.
^ When do you want to bring yours down? With the weather and heat we have been having I can work on it in the morning and have it ready by late afternoon. Got to clean out and make space in my garage first...got about 6 sets of tail lights that I just tinted and cleared tonight...lots of fumes in there.
