View Full Version : New owener..
XDriver
03-24-2008, 06:00 PM
Hello, recently bough a Black XD, will post pics after i get some wheels. :)
Quick question to our current Scion experts. Will this wheel Fit in the car sporting 225-40-18's ?
http://www.streetdreams.org/wheels/rims/Enkei/RZ-5/Gunmetal/18/7.5
Thanks .....:)
blkvulcan
03-24-2008, 09:06 PM
not if you can't get it in 5x100. As far as size, I'm not sure.
tmrepp
03-25-2008, 02:15 AM
18's are going to be a little close at full throw and 7.5 wide. Offset isn't low enough to make it worse, but it'll be close. Can't say for sure. But those wheels don't come in a 5x100 lug pattern. 5x114.3 will NOT work under ANY circumstances.
edit: I'm putting on 17x7.5 with +48 offset..which is as big as I am willing to go without test fitting before I buy them.
XDriver
03-25-2008, 02:53 AM
Cool, yea I dint realice it was 4x100 and 5x114.3 fitment only. Thanks
Im also looking at.
Enkei FN-18: 18x7.5 :: 5x100 :: 42mm offset :: Gunmetal
http://memimage.cardomain.net/member_images/8/web/2672000-2672999/2672574_9_full.jpg
Venti V56: 18x8:: 5x100 :: 45mm offset :: Black with Machined Li
http://memimage.cardomain.net/member_images/8/web/2672000-2672999/2672574_10_full.jpg
What do you guys think?
tmrepp
03-25-2008, 02:57 AM
i wouldn't buy them that big until either a: someone has fitted the same size and offset with the same height tires you'll be putting on, or b: test fit it
Ya know? Go for a clean look, not tacky. Use your taste.
katchkillah
03-25-2008, 05:17 AM
well once i pick up my xd and put on rims i'll let you know, it's a more aggressive set up hope it will work.
ChelsDS
03-25-2008, 08:12 AM
I woud see if there is something with those same specs at a local wheel store and have them test fit your xD with them. That way to see what they look like and if there will be any potential problems with that size. If it works, then that shop might be able to special order rims that you want.
DiscountTireDirect
04-08-2008, 11:56 PM
Here's 4 pages of 18" Enkei (http://www.discounttiredirect.com/direct/filterWheelProducts.do?vid=012610&yr=2008&wd=18&rw=&bp=&c=4&fcb=Enkei&fcpr=*&fcs=*&fcf=*&fcst=*&x=36&y=11) wheels that will.
