View Full Version : Sometimes hard to put into 1st gear
BeQuietAndDrive
11-22-2004, 04:17 AM
Does anyone eve have the problem where sometimes, it's a little hard to put into first gear? Like, it has to be coaxed to go in? Mine does this sometimes.
UnFocused
11-22-2004, 06:22 AM
Its compleatly normal...When its cold, it will always be difficult. when i warms up after 10 or so minutes, it should be easier to get into gear...
hotbox05
11-22-2004, 07:59 AM
alot of cars are slightly hard to put back into first
SWF_05_tC
11-22-2004, 09:59 AM
First gear is generally not synchronized, the same with reverse. They do this so that you don't accidentally downshift to first, or shift into reverse while moving forward. It is completely normal.
BeQuietAndDrive
11-22-2004, 01:21 PM
Ah,gotcha. Thanks a lot.
I really hate the 1-2 shift though. Wish I could do something about it. It seems much longer than all the rest,haha.
Munch
11-22-2004, 01:28 PM
Get a short shifter 8)
bBted
11-22-2004, 05:18 PM
i have TRD short shifter....feels lot better
BeQuietAndDrive
11-22-2004, 08:44 PM
Does the short shifter make it too short? It seems like I would have to reach down the if the sihifter were much lower, haha.
Sciond
11-23-2004, 12:32 AM
Here is how to avoid diificulty. Shift into reverse first then go to first gear it will then slide right into gear
fireballfish
11-24-2004, 04:27 PM
the reason this works ^^^ is because in order to get from reverse to first, you have to go through neutral. if you need to do a 2-1 shift, double clutch, in that you let the clutch out in neutral before putting it into first... easiest way to do a 2-1 shift
hotbox05
11-24-2004, 05:23 PM
Does the short shifter make it too short? It seems like I would have to reach down the if the sihifter were much lower, haha.for the xa/xb the short throw shifter is only about .75 inch shorter in overall height
Sciond
11-24-2004, 09:00 PM
true I forgot to add that.........either way works :D
Sciond
11-24-2004, 09:34 PM
oops
4rjn
11-26-2004, 06:20 PM
yep mine is the same way it must be warm.
