Turbonetics turbo kit on AEM EMS! 323hp and 336ft/lbs....
Old Mar 27, 2008 | 12:29 AM
Mecanica_Pito's Avatar
Default Turbonetics turbo kit on AEM EMS! 323hp and 336ft/lbs....
Guys,
This is from a customer car!
2007 Scion tC RS3.0 with a Turbonetics turbo kit. The stock engine died spitting a rod through the block before installing the EMS at only 3,200miles . The new engine is 2006 and I installed Pauter connecting rods and Wiseco pistons (std bore). Also installed ARP head studs and cometic head gasket!
The numbers where made boosting 18psi BUT the car is still running the STOCK S-PIPE !!!!! It is hurting power numbers badly but the 2.5" S-pipe that was to be installed on the car didn't fit and we didn't wanted to loose the appointment with the Dyno!
This was done on 93 octane pump gas as usual!!
Pito
Old Mar 27, 2008 | 12:32 AM
draxcaliber's Avatar
and what PSI was this done at out of curiosity?
Old Mar 27, 2008 | 12:42 AM
Kydog's Avatar
With all due respect that seems awfully low.
Built motor, nice turbo kit, 18psi, 93oct and AEM Standalone making 323whp???
Old Mar 27, 2008 | 01:01 AM
It has a bone stock exhaust system including the S-Pipe! With a free flowing exhaust It will see about a 30- 35 hp increase at 18 psi!
Pito
Old Mar 27, 2008 | 01:08 AM
yamaha16bw's Avatar
yeah bigger exhaust and maybe a bigger turbo and the number should jump alot.
My brother hit 309whp at 10psi on the stock motor with a turbonetics kit with the Hydra. So the stock exhaust is killing the numbers.
Old Mar 27, 2008 | 01:14 AM
Scotty's Avatar
wow nice numbers!!...my tC's in the shop gettin pretty much the same engine build, pauter rods and all, im running the GReddy turbo kit with a 2 1/2" str8 pipe exhaust...id be extremly happy to dyno in at close to 300whp!!!! lol....but great work im lovin seeing all these whp numbers
Old Mar 27, 2008 | 02:04 AM
paul_dezod's Avatar
Scionetics
KAD
The numbers seem about right for a conservative tune, that size turbo and a stock exhaust. Nice work fellas!!!
Old Mar 27, 2008 | 02:07 AM
paul_dezod's Avatar
Scionetics
KAD
Spend some more time VVT-i tuning, and what her come even more alive.
Old Mar 27, 2008 | 02:08 AM
scionkidd's Avatar
Pito
tyr ptuning exaust... their turbo-back is around $950 and gives 45hp/70tq over stock exaust on 11psi boost... u should have more since you are higher on the boost mark. check them ou at http://www.ptuning.com/html/Item-Des...o&ModelDesc=tC
Old Mar 27, 2008 | 02:29 AM
Guru's Avatar
18 PSI is pushing that tiny turbo pretty hard. You can also see by the graph that power is not smooth and there are some inconsistencies there as well as an unusual hump with the torque chart. Open up the exhaust smooth out the map and try running a bit less boost. I suspect you are pushing her past her efficiency limits.
Old Mar 27, 2008 | 03:49 AM
I didn't tuned the VVT-i at all. I didn't even knew it was wired and connected up until a few days after the dyno!
Honestly I have to read up and gather more info on tuning cam timing as I have not worked with it yet!
Pito
Old Mar 27, 2008 | 03:54 AM
Originally Posted by scionkidd
tyr ptuning exaust... their turbo-back is around $950 and gives 45hp/70tq over stock exaust on 11psi boost... u should have more since you are higher on the boost mark. check them ou at ....
If 45hp/70ft/lb over stock was obtained on a Greddy kit at 11psi then I would expect even higher numbers with the Turbonetics kit at 18psi just as you said!!
Pito
Old Mar 27, 2008 | 07:00 AM
TurboToyotas's Avatar
What size ar is the turbine housing?
Regards-
Todd
Old Mar 27, 2008 | 12:16 PM
Regards-
Todd
0.48 A/R with a stage 2 wheel
Pito
Old Mar 27, 2008 | 02:01 PM
paul_dezod's Avatar
Scionetics
KAD
Regards-
Todd
Pito
Yep. Correct.
Try some VVT-i tuning and watch the bastard make GOBBS of TQ.
Old Mar 27, 2008 | 06:46 PM
bkuhl's Avatar
Paul, I definately need to come see you when I get back to the States...when that is, I have no clue yet :D
Old Mar 27, 2008 | 07:34 PM
Mr_Meaty's Avatar
Pito: did you get the air conditioner working on that car?
Old Apr 23, 2008 | 07:32 PM
Scion_RS-T3's Avatar
Yes
Old Apr 23, 2008 | 07:39 PM
Nick06tC's Avatar
Awesome work pito.
It deffinetly looks liek the exhuast is hindering it all. It just flattens out at a certain point.
Old Apr 24, 2008 | 03:51 AM
TCFROEZEL's Avatar
Nice work pito ... for a stock exhaust it is good numbers.
how dificult was the tune of the AEM compared to the e-manage ?
