Blueish..whitish smoke...
Coming out my exhaust every now and then. I haven't noticed that it does it at certain times...kinda random...any ideas? Oh yeah...it just started...well, that i notice
Dezod stage one...AEM F/IC 9.5PSI...
just to be safe, before you automatically jump to a blown turbo, do a compression test. i had a cracked ring landing and it was pressurizing the oil pan, not allowing the turbo to drain and oil was pushing passed the seals on the turbo, making it seem blown, but it wasn't.
Originally Posted by draxcaliber
Originally Posted by kikcaffine
It says he has a dezod stage 1 kit......
Start problem solving. Compression, remove turbo to check for oil, then go from there.
If its the older kits that came with turbonetics I put my money on that. If its a newer kit then you may have other problems.
Well...i kinda narrowed it down..it seems to only do it when I give initial throttle. Like leaving from a red light or stop sign...even then it only does it sometimes...it's weird. If something is wrong with the turbo already...I'm going to fix it and there is another kit for sale here on SL...
if you run too much pressure on turbo it could break the seals, the oil pressure light comes on when the pressure is low.. but non ballbearing prolly not an oil feed pressure issue
