another s/c question
Old Mar 28, 2008 | 06:33 AM
xunst0pablex's Avatar
Default another s/c question
as of yesterday. my s/c auto tc has been less responsive than usual. i mean its a pretty big difference. it seems as tho when i press the gas, the rpms go up high and fast as usual but the car doesnt accelerate up as fast. like the boost doesn't come in fast enough. i thought it might be cuz i need a oil change so i got it done, and i know for a fact i used 91 last fill up and i still dont know why its doing it. OH and then like it really happens in the morning an day...and then when i start it at night usually its okay and back to normal. now i do have the viper auto start on mine. can this make a difference? and when i start it regularly, it starts harshly. help?
Old Mar 28, 2008 | 01:48 PM
1OF1's Avatar
I have viper auto start on my s/c tC. I have a 5spd but my car runs fine
Old Mar 28, 2008 | 02:53 PM
BLUEMEANIE's Avatar
Team Hamster
I had that little white trumpet inside the air box pop loose and the difference in air flow to the MAF caused the ECU to put the car in limp mode.
Old Mar 28, 2008 | 04:50 PM
Gerard_gmaiz's Avatar
if the rpms go up and the car doesn't accelerate you might be out of clutch
i suggest a complete high performance kit
Old Mar 28, 2008 | 05:36 PM
cmv138's Avatar
he has a Auto.
Old Mar 28, 2008 | 05:43 PM
Danger_Darren's Avatar
They still have clutches, just not the same type.
Old Mar 28, 2008 | 07:33 PM
xCxHxRxIxSx's Avatar
they have torque converter not a clutch .
Old Mar 28, 2008 | 07:34 PM
DANIEL209's Avatar
Try checking all your connections and your belt.
Old Mar 28, 2008 | 11:33 PM
http://auto.howstuffworks.com/automa...nsmission4.htm read that. auto trannys still have clutches.
Old Mar 28, 2008 | 11:45 PM
Nick06tC's Avatar
Is it warmer out where you are than usual? I know my car is totally different from cold days to hot days.
Old Mar 29, 2008 | 01:23 AM
05-RS1's Avatar
i had this issue too..then i up'd the boost and problem went away..so far seriously, maybe you've gotten used to it.
Old Mar 29, 2008 | 07:08 PM
In this transmission, when overdrive is engaged, a shaft that is attached to the housing of the torque converter . lol your link proved my point even more
Old Mar 29, 2008 | 07:22 PM
i read more . i guess there is a "clutch" if you would call it that. but when you think auto the tourqe converter is what you think of .
Old Apr 1, 2008 | 04:39 AM
^^yeah. i know what you mean. I have seen older cars with trannys where those clutch plates wore out and they had similar problems.
Old Apr 1, 2008 | 06:12 PM
my bad
but it still could be a trany problem
auto has i think 2 one way clutches that if the friccion disc fails thw trany slips
Old Apr 1, 2008 | 07:20 PM
my bad
im saying tranny problem too.
Old Apr 1, 2008 | 07:32 PM
KillaSpiceTSW's Avatar
Default Your clutch.
Its your clutch bud. That happens when the clutch is slipping and not engaging properly. Trust me on that.
Old Apr 3, 2008 | 01:20 AM
sonofabeoitch's Avatar
could be a number of things, just need to get it checked out, torque converter, solenoids, or clutches. they might be able to run a couple of tests. might be leaking boost if your still on your stock BPV.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
