View Full Version : After Market Reception Problem?
dskize1
11-22-2004, 08:46 PM
i installed an after market radio over the weekend and know the FM reception is not good.
just wondering if anyone has expierienced this also? if so what did you do? will a booster work?
please let me know.
superjeer
11-22-2004, 08:49 PM
yeah, I put in a sony and I actually took it out to double check the antenna was plugged in. It was that bad. and it WAS plugged in. I'm lucky to get a station. Sucks hard.
what kind of head unit did you get?
dskize1
11-22-2004, 08:54 PM
believe it or not it is a Sony also CDX-F7705X
MotoMan_YZ400
11-22-2004, 09:06 PM
yup had the same prob.... the antenna is a powered antenna, powered by the HU... i simply had to hook up 2 blue wires, and bam! crystal clear... make sure you have your "antenna" wire from your HU connected....
RPMxB
11-22-2004, 09:18 PM
... FM reception is not good... just wondering if anyone has expierienced this also? if so what did you do? will a booster work?
Here's two threads that suggest answers to the problem of poor reception after adding an aftermarket head unit.
antenna... on the XB
http://www.scionlife.com/forums/viewtopic.php?t=8883&highlight=poor%2A+reception
Bad Stereo Reception
http://www.scionlife.com/forums/viewtopic.php?t=4295&highlight=poor%2A+reception
:wink: RPM
superjeer
11-22-2004, 09:22 PM
I thought I had done that.. but that might explain a lot! Time to yank it again. and after that I'll work on the radio :shock: :oops:
Fujiz_xb
11-22-2004, 09:25 PM
i get bad reception with stock HU..well on some stations
superjeer
11-23-2004, 01:35 AM
^^ yeah, the stock was nothing to write home about, but I simply can't get any stations now for most of my drive into work :(.
My old Blaupunkt got REALLY good reception. And, I didn't check, but I'm almost certain I hooked up that ant lead.
