View Full Version : Need some help!!!
OrAnGeBoX
11-23-2004, 12:48 AM
So I was wiring a new LED to the already exsistant lighting in the car when all of a sudden it no longer work none of it. So my cup holder illumination does not work the floor lights dont work and my new LED in the cubby on top of the glove doesnt work either.
I checked the fuses but none were blown
Ps.Every thing else works the turn signals headlights ect... :( :cry:
What am I missing?
Did I do serious damage?
How do I fix it?
BoomBox757
11-23-2004, 12:52 AM
check your ground and the power with one of those light things
OrAnGeBoX
11-23-2004, 12:55 AM
I have a hot lava and i have no idea where it is grounded
chadfo
11-23-2004, 01:06 AM
This might sound like a silly question but I learned a long time ago to check the simple stuff first. Have you taken the new LED back out of the wiring to see if everything else works without it? If everything works without it your new LED may be shorting it out. Check your wiring. It's usually best to tap the hot and make a new ground instead of tapping another wire.
BoomBox757
11-23-2004, 01:09 AM
I have a hot lava and i have no idea where it is grounded don't worry about were it grounds to,with your light thing hooked out to a power, just poke through the insulator and make sure that it grounds, then do the same to the power
OrAnGeBoX
11-23-2004, 01:30 AM
i disconected the led i put in with no result. I dont have a power meter :(
Does anyone know where the power to the stock lighting goes and or which fuse its hooked to?
OrAnGeBoX
11-23-2004, 02:10 AM
i guess ill be taking it to my friends shop 2 morow
BoomBox757
11-23-2004, 01:47 PM
power meter helps, if you don't have one I don't know how you would fix it, maybe you should iinvest in one
OrAnGeBoX
11-23-2004, 10:54 PM
I have fixed the problem.
just to let everyone know there is an inline fuse between the lights and the switch before the fuse box.
Just FYI
Thanks for all that tried to help.
MotoMan_YZ400
11-23-2004, 11:33 PM
ok stupid, but common question did you hook up the power wire backwards? LEDs are not light bulbs, they dont function backwards.... i dunno, just trying to help... i always find the stupid stuff is what goes wrong 95% of the time
