car stalls out at low idle
Old Apr 4, 2008 | 04:46 PM
slow-n-low06's Avatar
Default car stalls out at low idle
i just got my s/c installed and sometimes when it is idleing the car will just conk out. it usually happens when its a cold start
Old Apr 4, 2008 | 05:15 PM
Joe_Dezod's Avatar
2 Possibilities to start with:
Did you get the reflash? If you just put the higher flow injectors in with no reflash, it will run rich and possibly cause you to stall out. You also lose fuel efficiency and run too rich when driving.
Vacuum leak: If you just installed the S/C and it's idling rough to where it dies randomly, you may have a hose or the charge pipe loose somewhere. The MAF would meter incorrectly and you car would stall.
Old Apr 4, 2008 | 05:38 PM
dos_techie's Avatar
Is your TB (throttle body) clean? Dirty TB's full of carbon deposits can cause this concern. Clean it using a TB and intake cleaner. It comes in a spray can. I use it at work all the time.
Old Apr 4, 2008 | 05:42 PM
smilezdc's Avatar
mmmm... my car was idling all funny too.. it was my water pump..
Old Apr 4, 2008 | 05:45 PM
it only stalls when im at a stand still.
as far as the reflash goes toyota installed it and said they reflashed it.
when i run the car for a few minutes it wont stall out. but if i havent driven in it it will stall in drive. also im a auto if that matters
Old Apr 4, 2008 | 07:55 PM
Sciontistical_One's Avatar
check to see if your MAF sensor is dirty... if it is, that may be the root of your problem...
Old Apr 5, 2008 | 08:52 PM
took it out, blew a little air in and hasnt stalled since. thanks
Old Apr 5, 2008 | 11:02 PM
tCZion's Avatar
My car does the same when S/C installed and a week later ore more get back to normal. the weird idle was the computer reset by battery disconect. If I disconect the battery now will do the same again.
Old Apr 7, 2008 | 12:10 AM
jjos1's Avatar
When you start it do you turn the injnition on and wait a second before you start it or do you just put the key in and start it right away ? For some reason I noticed alot of people mentioning that if they waited a second or 2 it would start up fine. I don't know when you change the small fuel line if it does something.
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
DibujoB
24
Jun 28, 2004 04:23 AM
tC_Normo
Oct 22, 2003 07:20 PM
andergtr
Oct 17, 2003 12:35 AM
