Whats up with my suspension??? rear sway bar????
So, my tC has been riding rough. front is rough but the back is bad. if i am in a turn at almost any speed and hit a bump or seem in the road i can feel the body move in the rear. sometime a lot, sometime just a little.
i have had a tire that looses pressure for a while now due to a VERY slow leak. i thought that was the problem for a while but now it is apparent that it is much more.
any thoughts?
any thoughts?
1st guess -
Tires are really worn. When tires start to go, they don't grip, make all kinds of noises, and are just pain uncomfortable. The sidewalls don't flex and rebound like they used to. The tread design screws up causing vibrations, etc. etc.
I'm about 95% sure it's the tires.
I'd get those checkd out first. In addition, alignment might be off. They recommend you get an alignment once/year , or every other year, if you're not racing it. This would be secondary to the tires, though.
With zero mods, we can't blame the mods or any errors in installation of them.
You're also still too early to need to replace any wear-items.
So, i'm gonna order at least 2 new tires, to take care of my slow leak. thats first.
but i dont know if its just poor tires. the one time i really felt like it was bad was coming arounda turn i hit a seem in the road and both my head and the passengers heads just whipped to the side. the front of the car stuck firm but the back moved a whole lot.
And the thing is, what your describing seems a lot like oversteer (or in our FWD cars, power-sliding)... which is very contradictory to how the car was originally designed.
See, when turning, our cars tend to not turn as much as we tell it to. The car continues forward, rather than laterally. If we upgrade our suspension and whip around a corner, then the front grips big-time, and the inertia of the rear-end forces it to come around.
But the issue is... you don't have suspension upgrades.
I suspect the rear tires are just not doing their job anymore. Your front tires seem to have some grip left to them. Perhaps they got really worn down, then rotated to the back?
It's really hard to say without looking at or driving the car myself, but I'm just working with what I got. Replace the two tires, and put the two new tires on the front wheels. Move the current front tires to the rear. In that way, you'll have more grip where it counts, and still a good bit of grip in the rear for the stability.
You may want to consider just shelling out and replacing all 4.
There are a number of great bang-for-buck tires in the 80/tire range.
I've been on Fuzion ZRi's, and they're awesome. Quiet, stick pretty well, channel water well, and still grippy after about 25k miles on them.
Avon tech M500's are very close to those. A little grippier.
General Exclaim UHP's - also extremely good bang-for-buck.
BFG - g-force sport. These guys are a little louder and don't do as well in the water, but they're decent.
Could be deflection of the rear suspension bushings. Some people are more sensitive to that then others, and it's just a possibility, not necessarily your issue. Sport Compact Car magazine discovered the bushings were a weak point, after they placed coilovers, anti-sways and a serious wheel-tire package. They found the rear end was still loose, with the bushing deflecting such that the rear suspension moved as much as half an inch at it's mounting points. They resolved it by swapping out the bushings with urethane from Energy Suspension, iirc. I'm considering the same thing, as the rear of mine feels that way too, after installing TRD springs and rear sway on track setting.
Excellent point nodsetse.
If he had mods, I'd definitely consider it. But when you consider he's on the stock sway and stock endlinks, those almost flex as much as the bushings, so the bushings might be spared.
In fact, I'm thinking about changing those bushings on my car as well.
If you want all seasons, I can recommend the Avon Tech M550's enough. The M500's are summer tires and have been given some very good words. The 550's are one of the best all seasons I have driven, especially for $100 a pop off tire rack.
I currently have Falken Ziex's on it, which were cheaper than the Avons through discounttiredirect. They are nice tires, but not up to par with the Avons IMO. I will go back to Avons on my next set.
Ordering Falken Azenis in a day or two.. but those are for the spare wheels and the autox course
Thanks sensi! Happy pre-bday to you as well!
Originally Posted by mcstagger
all the tires you guys listed look good. are they equal or better then the original tires?
They're all better than my stock tires. My '08 came with the Bridgestone Turanzas. I hate them... damn all seasons..... I'm just going to be patient and replace with good tires once they wear out. Too bad that'll take like 30,000 miles.. Only 26,000 more to go. sheesh
I got the Kumhos Ecsta ASTs dirt cheap at discounttiredirect.com. FREE shipping! (They had a deal at the time when you bought 4, they gave you $40 back via mail-in rebate.) These tires are a lot more quiet than the Falkens I had. Read the reviews on them. Good all-season tires. GL.
airmankevin1
Feb 14, 2018 01:23 PM
Squishface
Sep 15, 2015 06:51 AM
TheTripleC
Jan 4, 2015 06:46 PM
