supercharger impeller seal
Old Apr 5, 2008 | 01:47 AM
sonofabeoitch's Avatar
Default supercharger impeller seal
took apart the s/c found the seal part number on the seal is 2A060-12. the rubber/plastic is chiping off. i was wondering how do i cross reference this piece? the dimensions are 18mm X 30 mm X 10 mm. is it easy to find?
Old Apr 5, 2008 | 03:06 AM
jjos1's Avatar
What part did you pull the bearing from ? only the pulley side should have a rubber seal. The rubber seal is part of they skf 6205 /rs bearing. The only other seal is the viton seal on the shaft.
Old Apr 5, 2008 | 03:47 AM
kikcaffine's Avatar
^ no there is an impeller shaft seal aswell. Your looking right at it. Thats a vortec specific part number.
VORTECH Seal 2A060-12
viton seal single/double lip covered steel:
24mm or 25mm
40mm
7mm
Old Apr 5, 2008 | 04:13 AM
jjos1's Avatar
Thats the viton seal ? looks like one of the skf bearings
Old Apr 5, 2008 | 04:19 AM
kikcaffine's Avatar
no its a hard plastic seal. that maybe the wrong part number I pulled up. I grabbed it form another website
Old Apr 5, 2008 | 06:51 PM
yea the part number is 2a060-12. i wanted to see if there was a possibility of a cross reference to that seal. it seems as if it spring loaded.
Old Apr 5, 2008 | 10:42 PM
kikcaffine's Avatar
It is. I thought it was a plastic seal that was against a rubber o-ring.
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
rain7905643
Jun 13, 2018 05:29 AM
corbinortiz
Oct 2, 2015 02:45 PM
MisterSkiz
Sep 27, 2015 10:25 PM
