Does the treble go to both front speakers AND tweeter?
If I install full range coax speakers in the front doors, I want the treble to go to both them AND the oem tweeter. Is that the way it already works? Or do I have to modify the wiring to accomplish this?
Thanks in advance !
Thanks in advance !
I've just read that the signal delivered to the front door lower speaker is in fact full range. That's exactly what I want, so unless someone knows otherwise, looks like I have my answer!
If you just drop in coaxial speaker into the front doors you will in fact hear sound from both the coaxials and the stock tweeters. If you remove the stock tweeters, you will get no sound unless you jumper the tweeter wires together to complete the circuit. I jumpered those wires and put in component speakers. Have you thought about components? They'll probably sound better than the coax+stock tweeter combo.
But what you said confuses me now too! Why did my new components only work when I shorted the original tweeter wires? They must not be in parallel, right? Did I do something wrong? Wow... I've been runing my comps this way for several months and everything is fine. I need to investigate a little bit...
(edit) I'm still stumped and should actually be getting stuff done at work now. Let me know if you figure it out or if what I said is completely wrong. I belive I remember things correctly but my memory could be a little fuzzy. I may have to pull out the original tweeter wiring just to satisfy my curiosity.
OK, I'm obviously not working - haha.
Check this out:
http://www.fsu-clan.com/scion/audio/audio%20wiring.pdf
It looks like the tweeter is in parallel with the woofer, so why did I have to jumper the tweeter wires? Man maybe I'm seriously trippin', but I'm fairly certain that's what I had to do to make my components work. I'd hate to give out false info so please take whay I say for what it's worth (not much at the moment!).
I'll post back if I take my wiring out and double check what I did.
Check this out:
OK I got it. taking a closer look at the wiring diagram I linked, the tweeters have a 4-prong plug connected to them (I thought it was only 2). Take plug "E5" for example. Points 2 & 4 are getting (-) and (+) speaker signals from the head unit. The points 1 and 3 deliver the signal to the woofer. The tweeter is the physical connection between points 3&4 (+) and 1&2 (-). I had to jumper 1-2 and 3-4 in order to get the signal to the woofers with the stock tweeters removed.
Clear as mud? Check out the the diagrams and it should be clear. I feel redeemed now, and less crazy!
OK, that makes sense, you have to bridge 3 to 4 and 1 to 2 for both connectors D5 and E5, otherwise no signal gets delivered to the lower speakers. On the other hand, bridging 2 to 4 or 1 to 3 would put the amplifier at serious risk !
I just installed two pair of Alpine 6-1/2" coax drivers in the doors, and kept the oem tweeters. I'm finding the sound very enjoyable and the output from the two sets of front tweeters seems to meld nicely. Best sound I've personally ever had in an automobile -- I'm satisfied ! (Much better than oem.)
MyNameIsMud
Scion FR-S ICE & Interior
03-04-2015 05:27 PM
clickclickw00t
02-18-2015 08:57 PM
