Supercharger help!
Old Apr 7, 2008 | 07:50 PM
rjweitzel's Avatar
Default Supercharger help!
i just purchased a trd supercharger for my 07 tc, but its just the supercharger assembly, does anyone know where i can buy all ther rest of the parts i need to install the s/c? someone told me about an install kit but i cant find anything on it.
Old Apr 7, 2008 | 08:05 PM
kikcaffine's Avatar
Wow, your in for quite a task. You need alot of stuff. injectors, the tune, all the intake tubing, oil block, feed lines, thermostat, spark plugs. Do you have a picture of what you got exactly so we can better help you?
Old Apr 7, 2008 | 08:10 PM
rjweitzel's Avatar
its just the s/c assembly
Old Apr 7, 2008 | 08:11 PM
rjweitzel's Avatar
Old Apr 7, 2008 | 08:13 PM
draxcaliber's Avatar
hope you got it for really really really cheap because your going to have fun buying and getting those parts.
why would you buy the supercharger and then have to assemble it yourself? you'll have all the power of the supercharger with none of the warranty!
kikcaffine's Avatar
Do you have a picture of the compressor side?
Your going to need this list of stuff.
TRD, Emblem, "Supercharged", Plastic Blister Type PTR01-3500E-MB
TRD, Emblem, Small Rectangular, Plastic Bubble Type PTR01-3500T-RD
TRD 2.4AZ S/C, Cold Plug Replacement Part PTR24-21050-00
TRD, Spark Plug PTR24-21055-01
TRD 2.4AZ S/C, Rear Bracket Replacement Part PTR25-21060
TRD 2AZ S/C, Drive Belt Replacement Part PTR30-21060
TRD 2.4AZ S/C, Wire Harness Relocation Kit Replacement Part PTR41-21050
TRD 2.4AZ S/C, Bracket Kit, AC Hose / Wire Harness Relocation Replacement Part PTR41-21051
TRD 2.4AZ S/C, Oil Feed Line T-Adaptor, AN to NPT Fitting, ByPass Valve Tee Replacement Part PTR41-21052
TRD 2.4AZ S/C, Idler Bracket Bolt w / Oil Return Line Hardware Kit Replacement Part PTR41-21053
TRD 2.4AZ S/C, Valve, Bypass Replacement Part PTR41-21054
TRD 2.4AZ S/C, Air Box Assy Kit Lower w/inlet Adaptor Replacement Part PTR41-21055
TRD 2.4AZ S/C, ECU Remap Module Replacement Part PTR41-21056
TRD 2.4AZ S/C, Crank Position Sensor Wire Ext. Assy. Replacement Part PTR41-21057
TRD 2.4AZ S/C, VSV Rubber Mount, VSV Hose & Bypass Valve Hose Kit Replacement Part PTR41-21058
TRD 2.4AZ S/C, Hose, Oil Feed Assy Replacement Part PTR41-21059
TRD 2.4AZ S/C, Rear Mounting Bracket, assembly, Aluminum Cast Replacement Part PTR41-21060
TRD 2.4AZ S/C, Crankshaft Bolt Replacement Part PTR41-21061
TRD 2.4AZ S/C, Idler Pulley Replacement Part PTR41-21062
TRD 2.4AZ S/C, Driven Pulley w/Hardware Kit Replacement Part PTR41-21063
TRD 2.4AZ S/C, Air Box Rubber Mounts & Sleeves Replacement Part PTR41-21064
TRD 2.4AZ S/C, Driven Pulley Shim Asst. Kit Replacement Part PTR41-21065
TRD 2.4AZ S/C, Clamp Kit Replacement Part PTR41-21066
TRD 2.4AZ S/C, Idler Pulley Hardware Kit Replacement Part PTR41-21067
TRD 2.4AZ S/C, Inlet Cover Replacement Part PTR41-21068
TRD 2.4AZ S/C, O-Ring, Supercharged tC Replacement Part PTR41-21069
TRD 2.4AZ S/C, Oil Pan w/ Return Tube Replacement Part PTR41-21160
TRD 2.4AZ S/C, Thermostat, 70C / 160F Replacement Part PTR41-21161
TRD 2.4AZ S/C, Formed Fuel Line Assembly Replacement Part PTR41-21162
TRD 2.4AZ S/C, Fuel Injectors, High-Flow Replacement Part PTR41-21163
TRD 2.4AZ S/C, Gasket, HC Trap Holder, Buna Replacement Part PTR41-21164
TRD 2.4AZ S/C, Insulator, Exhaust: Stamped Replacement Part PTR41-21166
TRD 2.4AZ S/C, Hose Kit: Inlet/Outlet/Bypass Replacement Part PTR41-21167
TRD 2.4AZ S/C, Hose, Water Return Replacement Part PTR41-21168
TRD 2.4AZ S/C, Oil Return Hard Line Assy. Replacement Part PTR41-21169
TRD 2.4AZ S/C, Rear Bracket & Inlet Cover Hardware Replacement Part PTR41-21170
Power Out Puts
Old Apr 7, 2008 | 08:21 PM
rjweitzel's Avatar
damn thats alot of parts , thanks for giving me the list tho,
i only paid 800 for it, i wonder how much all the parts are gonna cost
Old Apr 7, 2008 | 08:24 PM
kikcaffine's Avatar
Your boned. Sell it and just buy the kit new. You will need so much stuff its not even funny. Probably close to 3 or 4 grand in parts.
Old Apr 7, 2008 | 08:31 PM
rjweitzel's Avatar
just called my dealer and they said they can get me the parts i need for $1100
Old Apr 7, 2008 | 08:32 PM
kikcaffine's Avatar
For everything? i dont believe it. The reflash module is 700 dollars alone.....
Old Apr 7, 2008 | 08:41 PM
rjweitzel's Avatar
dont they reflash at the dealership?
Old Apr 7, 2008 | 08:43 PM
kikcaffine's Avatar
you have to buy the module. Its a 1 time use.
Old Apr 7, 2008 | 08:46 PM
rjweitzel's Avatar
damn they didnt tell me that
Old Apr 7, 2008 | 08:47 PM
kikcaffine's Avatar
yeah it sucks. True story.
You better start looking for EMS now.
Old Apr 7, 2008 | 08:52 PM
rjweitzel's Avatar
does anybody sell them online?
Old Apr 7, 2008 | 08:56 PM
kikcaffine's Avatar
Which ems? yeah greddy make them so does AEM. Your best bet though is to seriously sell it and just buy a complete kit at once so you get everything thing you need.
Old Apr 7, 2008 | 09:06 PM
rjweitzel's Avatar
wat does the ems do?
Old Apr 7, 2008 | 09:14 PM
engine management system.
the tc's stock ecu won't know how to work with the supercharger, and runing a supercharger without the trd reflash will result in a blown engine.
so you have to tune the car with a piggyback, or a full blown engine management system.
Old Apr 7, 2008 | 09:21 PM
rjweitzel's Avatar
when they do the fash at he dealer do they do that?
Old Apr 7, 2008 | 09:25 PM
they reflash is a module that comes with the supercharger kit, and is done by the tech usually after everything is installed.
