Pix Please of you camber
Hello everyone, I'm asking to see a pic of your lowered tc's Camber.. I think mine needs adjusting (Rear).. front looks fine. But still taking it for an alignment next week. I'm not having any increased tire wear as of yet.
dave's camber looks fine, its just the picture that throws you off.
its ok to have some neg. camber left over even after alignment. if you want to get it perfect to 0 (not recommend) you'll probably need rear camber links.
most important thing is make sure they adjust your toe perfectly... fked up toe will wear down tires quickly.
rvpps2rocks the way you describe it makes it sound like im running Positive camber. no way dude. im running a bit of neg camber and yes it chews through tires but i dont think its a big deal plus if i still have some room after i put my 15mm spacers on then ill straighten the wheels out a bit. we'll see
2. true a tiny bit of neg camber is good for going in corners (mostly in the front) but 0 in the back isnt bad
3. toe is important to get corrected, thats what causes the pull. camber is a tire wearing alignment angle and needs to be corrected to get the longest life out of your tires not just toe.
