Full Exhaust Suggestions Please
Old Apr 8, 2008 | 07:47 AM
Steventc07's Avatar
Default Full Exhaust Suggestions Please
Alright I have decided to sell my TRD Muffler and go with a full exhaust and get me an Intake. Heres what i'm thinkin
Intake- Injen CAI
Skunk 2 exhaust
S-pipe-?? advice please
Header-?? need advice
Is there a header that causes less rasp than the others. My plan is to get an Aero AR25 Resonator (thanks tCeeder) and a high flow cat if rasp persists as well as keep the resonator already on the skunk 2. what do you guys think?
Old Apr 8, 2008 | 07:53 AM
Aroddalobster's Avatar
mmw produces a bit less rasp than most other ones, but there are a lot of complaints about fitment, price, and installation being a pita. i personally have that exact setup, injen cai, mmw header/s-pipe, skunk2catback, and the sound is amazing.
Old Apr 8, 2008 | 08:20 AM
Steventc07's Avatar
do you have a lot of rasp or have you done stuff i.e. installed resonators to fix it or what, also do you have the antifouler setup and how does that work for you? I have read that some headers are more prone to throw the CEL
Old Apr 8, 2008 | 11:54 AM
Rizzie's Avatar
I dont know if my turbo has anything to do with it but I have the tc sportline catback and an ebay s-pipe which is all great quality and no rasp at all
Old Apr 8, 2008 | 12:55 PM
op07tc's Avatar
eh, another header thread....
i have the dme header w/ the skunk2 exhaust and a hi-flow cat. the dme has an oem style bracket at the bottom that bolts up to the original bracket, which keeps the header from vibrating and reduces rasp. then i got a jvt s-pipe and a vibrant cat welded into the skunk2 and it sounds great. not quiet by any means, but not ricey
Old Apr 8, 2008 | 05:39 PM
i just installed a normal cheap cat converter, since i couldn't handle the smell, and it turned out to help quiet down my exhaust a bit and got rid of the rasp too. and about the antifouler, my header and s-pipe came with a cel tricking thing, which has been working up to this day, and its been about a year since i installed it.
Old Apr 8, 2008 | 07:31 PM
Steventc07's Avatar
alright thanks guys. I know these questions have been asked many times before but I wanted to get an opinion and clarification as to which exact setup would work thanks for the help
Old Apr 15, 2008 | 03:50 PM
thecar's Avatar
i have the mmw header to a megen mid pipe and a trd axel back plus i put the AR2.5 res in and it still has rasp and sounds like ____.....what do i do to help this?
Old Apr 15, 2008 | 04:46 PM
Steventc07's Avatar
actually that does help me even more cause I have my TRD now and I know for sure to get rid of it for the setup I'm tryin to run, thanks man
Old Apr 15, 2008 | 05:33 PM
BlckdOutTC's Avatar
I've heard this the MMW makes least rasp but is big bucks but is worth it i think. That comes with an s pipe so that takes care of that. I'd go with a megan mi pipe and slap a good 20" resonator, and a high flow cat if you want, then the axle back of your choice
Old Apr 15, 2008 | 06:04 PM
thecar's Avatar
would the high flow cat cut the hp? and i do have the areo 2.5 res that is suppose to cut out the rasp but it didnt do anything
Old Apr 15, 2008 | 07:13 PM
BlckdOutTC's Avatar
go to an exhaust shop and have the weld on a 20'' reonator or larger. the high flow cat will not cut the hp in anything noticeable
Old Apr 15, 2008 | 10:40 PM
silverstreaktc's Avatar
skunk2 is a really good exhaust. a bit tricky to bolt to the midpipe but since ur putting in another one, put them on together first.
cid_mcdp
Jan 5, 2015 02:45 PM
AbsoluteRedtC
Dec 31, 2014 06:18 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
gularti
Dec 4, 2014 01:21 PM
