What is the a/f sensor?
Old Apr 12, 2008 | 03:20 AM
MikeC's Avatar
Default What is the a/f sensor?
Does it stand for airflow sensor, and can I get one only at the dealer? Yes I am changing my manifold to a header. Thanks in advance all.
Old Apr 12, 2008 | 04:14 AM
TcPrincess's Avatar
its the a/f radio sensor. don't get one unless you KNOW you need it, they're expensive. they do tend to strip but i've done MANY without stripping them.
Old Apr 12, 2008 | 04:36 AM
draxcaliber's Avatar
its the air/fuel ratio sensor, also known as the primary oxygen sensor.
Old Apr 12, 2008 | 04:55 AM
MikeC's Avatar
Well, mine is deffinately jammed as jammed can be. It's kind of embarassing. How much are they anyways?
Old Apr 12, 2008 | 04:57 AM
http://www.trademotion.com/partlocat...06&catalogid=2
that much. get some wd-40 on it.
Old Apr 12, 2008 | 04:58 AM
tCeeder's Avatar
i think it reads the mixture of burnt air/fuel from the cylinders. many are cross threaded from the factory, many are not. if yours begins to loosen (left) with ease and then suddenly stops, you'll probably going to need a new sensor.
Old Apr 12, 2008 | 05:05 AM
TcPrincess's Avatar
ya, if yours just STOPPED then you'll probably need a new one. you could try working it back and forth but it probably won't work. GL.
Old Apr 12, 2008 | 05:20 AM
MikeC's Avatar
I've tried everything, and it is stuck. Oh well for me, hopefully the dealership will have one on the shelf. Thanks everyone, this is why I am so happy to be a Scion owner.
Old Apr 12, 2008 | 05:27 AM
TcPrincess's Avatar
they should have one. i know we have tons because of the problem that the camrys had with their cats going out.
Old Apr 12, 2008 | 06:00 AM
MikeC's Avatar
Really? I'm actually from Yuba City, so if I was home I could just drive down 99 and get one.
Old Apr 13, 2008 | 12:42 AM
TcPrincess's Avatar
damn, saw this too late, if you like i can get you a P&A on monday.
Old Apr 13, 2008 | 06:49 AM
MikeC's Avatar
It's cool, I went down to the local dealer and shilled out the dough. At least the header's on now, and it is noticeable. Thanks nonetheless though.
Old Apr 16, 2008 | 07:36 PM
insanezane's Avatar
those things are like 300 bucks!!! i stripped mine and all i did was just took a triangle shaped file and when over all the treads and cleaned them up...it slid right in after that!! 300 bucks saved!!
Old Apr 17, 2008 | 01:11 AM
hustler900's Avatar
Yeah the dealer is the last place I would go to get an O2 sensor. People need to either try to clean up the threads or get one from an auto parts store.
Old Apr 18, 2008 | 01:07 AM
HighMPGTesting's Avatar
I don't know what mm size the A/F sensor is, but a simple search for a 24 mm die on amazon:
http://www.amazon.com/s/ref=nb_ss_gw...words=24mm+die
yielded only about $15 + shipping & tax (if any). I guess you would want both the tap and the die to ensure that the header as well as the cat threads were clean.
Still, $30-$50 and 30(?) minutes of careful labor is a LOT less than $300... and, if it happens again, you are ready for it.
Old Apr 18, 2008 | 02:46 AM
TcPrincess's Avatar
most of the time the die won't work because the sensor has very few thread and they are very coarse.
Old Apr 19, 2008 | 03:57 AM
Doah!
Thanks for the info. I haven't seen one up close & personal yet...
Old Apr 22, 2008 | 04:46 AM
MikeC's Avatar
Update, I never could get the sensor out of the old manifold.
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
prescottn
Sep 22, 2015 01:30 PM
gqdabien
Sep 17, 2015 09:23 PM
Topfueltom69
Sep 6, 2015 05:25 PM
