Clutch Buzzing?
Old Apr 12, 2008 | 08:01 AM
Griever's Avatar
Default Clutch Buzzing?
This problem has been going on for a while now, but now that I'm going turbo I'm really concerned as to what may be causing this? Whenever I shift, the clutch pedal makes a noticeable buzzing sound if I shift past 3k rpm.. It also buzzes faintly whenever I shift into neutral put the parking brake up. Any ideas on what could be wrong with my clutch?
Old Apr 12, 2008 | 09:37 PM
tCmaniak's Avatar
your car is probably going to explode...
honestly tho if your getting a turbo I would recommend a clutch upgrade anyways. Dont bother paying to fix it if there is something wrong
Old Apr 12, 2008 | 11:49 PM
tcdaily's Avatar
pilot or throw out bearing.. when you upgrade your clutch it should come with both..
Old Apr 13, 2008 | 05:35 AM
Griever's Avatar
Which clutch and flywheel kits would come with the new pilot and throwout bearings? Yea I was planning on upgrading my clutch in the future but I figured I may as well make use of my stocker
Old Apr 13, 2008 | 05:43 AM
tcdaily's Avatar
^^ The clutch i'm selling does.. haha but i don't know if you have use for a stage 5 clutch or not..
Old Apr 13, 2008 | 10:54 AM
Griever's Avatar
Haha yea stage 5 might be abit overkill for my setup lol. But how much are you selling yours?
Old Apr 13, 2008 | 06:17 PM
tcdaily's Avatar
check me sig out
Old Sep 20, 2008 | 02:23 AM
kev9910's Avatar
Hi Guys, I changed out my clutch to ACT street clutch and Fidanza flywheel set up. I got the same problem at around 3k rpm when i decelerate i get a buzzing noise.
The mechanic said it could be because a pilot bearing wasn't installed. The ACT kit didn't include a pilot bearing . Does a TC even need a pilot bearing? Where can i find one? i searched all over the web, went to a bunch of auto stores they do not sell it alone, they all come with a kit.
please help I'm debating if I should bring my car in tomorrow.
thanks,
Old Sep 20, 2008 | 05:57 AM
Griever's Avatar
Bump! Anyone have an answer?
Old Sep 20, 2008 | 11:13 AM
toyota_scion_tc's Avatar
thanks,
The mechanic doesn't know the tC! I have replaced my clutch and had a slight noise, mine was caused by throwout bearing being bad. The tC doesn't use a pilot bearing the input shaft on the transmission is rounded off at the end and this sits at the end of the crankshaft of the engine.
Old Sep 20, 2008 | 12:55 PM
kev9910's Avatar
I had a bent release bearing/throwout bearing installed before, it made whirling sounds at idle. But i had that replaced with a new oem throwout bearing, and the whirling sound disapeared.
Now it's a different sound, the sound the first post described, a buzzing sound at declerating 4th gear and 5th around 3k rpm is the most noticeable.
do you guys know what it could be? maybe the flywheel is too light and cannot absorb all the vibration?
how can i get this fixed? its really getting on my nerves.
thanks,
Old Sep 20, 2008 | 02:57 PM
B_Real45's Avatar
Buzzing sound upon deceleration is caused by light weight flywheels. This, I was told by Paul at Dezod.com, is normal for light weight flywheel setups.
Do not worry - as mine does this too. I've grown to actually like it. It sounds like a buzzing, or sandpaper type sound.
But as far as the OP is concerned - he doesn't have an upgraded clutch/flywheel - so I'm not sure what his issue is.
Old Sep 22, 2008 | 09:48 PM
kev9910's Avatar
Thanks alot for the information, makes me feel so much better now. Was worried about this for months.
Old Sep 24, 2008 | 09:07 PM
Comp_Clutch's Avatar
def sounds like t/o bearing hit me up if I can help answer any questions for you sir.
Chris H.
Competition Clutch
yhwhdesign
Jun 11, 2021 03:34 PM
a23r
Feb 1, 2016 04:05 AM
carbinefreak
Sep 24, 2015 02:06 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
scionsux
Sep 2, 2015 05:30 AM
