Noob subwoofer install questions
Old 04-14-2008, 08:02 PM
memebag's Avatar
Default Noob subwoofer install questions
I bought a Fusion subwoofer pack (speaker, enclosure, amp, lots of wires) and I have many questions about installing it. I'm handy with electronics, but haven't done much car audio.
First 2 questions:
Where's a good place to get the 12v for the amp?
Where's a good place to ground it?
memebag is offline
Old 04-14-2008, 08:29 PM
ExplorHer's Avatar
Q: Where's a good place to get the 12v for the amp?
A: Battery.
Q: Where's a good place to ground it?
A: Chassis.
ExplorHer is offline
Old 04-14-2008, 08:31 PM
CarbonXe's Avatar
A: Battery.
A: Battery.
Fixed.
CarbonXe is offline
Old 04-14-2008, 10:24 PM
memebag's Avatar
Can anyone be a little more precise? I understand that I need to get 12v from the battery and ground to the chassis, but anyone have experiences that might help? I've looked for threads about it, but found none that provided this sort of detail.
memebag is offline
Old 04-14-2008, 10:38 PM
lvbitwiz's Avatar
just to make it easy
https://www.scionlife.com/forums/viewtopic.php?t=219151
before something goes arcy sparky
lvbitwiz is offline
Old 04-16-2008, 05:13 AM
blazin_xb2's Avatar
Im new to the Xb but i have installed a few systems in other cars. The 12v will need to come from the battery and be fused, then ran throught the firewall (i believe there is a grommet on the pass side behind the glovebox) and then all the way to the back. The ground can be bolted to any body or chassis point but will need to be no longer than 18in and you should grind away any paint in the area. If it has a remote turn-on cable you will have to find that in the radio's harness. The rca's will also have to come from your headunit.
Hope that helps!
blazin_xb2 is offline
Old 04-19-2008, 01:00 AM
memebag's Avatar
Hope that helps!
Thanks! I've decided to mount the amp under the passenger side seat. I've got everything figured out except ... I can't find one of my nipples. The driver's side nipple, to be exact. Many posts mention a grommet on the driver's side with a nipple you can cut off. I can see where the wires come out inside the cabin, but I can't see where they go in under the hood. There's a pic in https://www.scionlife.com/forums/vie...wall&&start=20 but it isn't clear where the wire goes.
Any advice would be greatly appreciated.
memebag is offline
Old 04-19-2008, 03:31 AM
Whispaz's Avatar
your nipple should be near your armpit...
for realzzz though, push it from inside out. easy
Whispaz is offline
Old 04-19-2008, 04:11 AM
memebag's Avatar
The cable's got a big metal ring connector on the end I want at the battery. I don't want to jam that through, or lop it off.
memebag is offline
Old 04-20-2008, 12:59 AM
memebag's Avatar
Nevermind, I went through the passenger side and it was a breeze. Everything worked like a charm.
memebag is offline
Old 04-20-2008, 01:45 AM
Whispaz's Avatar
yea, i ended up doing the same but only because i didnt know about the drivers side one earlier
Whispaz is offline
Old 04-21-2008, 09:23 PM
memebag's Avatar
I bought the Fusion EN-PK112 from Fry's for $150:
It took about 4 hours to install, and I've never done a sub before. It came with all the cables and fuses and such. It sounds very good with the premium HU. I velcro'd the amp to the carpet under the front passenger seat, the sub fits on one side in the back, facing rear. I didn't tie down the sub, it's just wedged up agains the back seat. Nothing has moved it so far.
I'm looking around for a good way to quickly connect and disconnec the sub for times when I need the storage space.
memebag is offline
herwig
Scion tC 1G ICE & Interior
03-23-2015 04:19 AM
CPL_Radar
03-05-2015 05:42 AM
TotalChaos
13
02-04-2015 10:24 PM
wiltonhall
01-28-2015 03:46 PM
TheRedBox
31
12-02-2003 04:53 PM
Quick Reply: Noob subwoofer install questions
