check engine light question
Old Apr 15, 2008 | 03:46 AM
calvinhuh's Avatar
Default check engine light question
if my oxygen sensor on the header has any leak
will my cel go on???
Old Apr 15, 2008 | 04:38 AM
BuddhasTC's Avatar
yes
Old Apr 15, 2008 | 06:42 AM
calvinhuh's Avatar
hmmmm well i htink my o2 sensor is leaking .. i cant tell...
the bolt thread got messed up so i couldnt put it in allthe way...
but i had the check engine light ... for about 2 days..
and today the cel dissapeared.
wonder wats goin on...
Old Apr 15, 2008 | 06:44 AM
AcidDrop's Avatar
definately, and if you have aftermarket headers then you will get the CEL.
Old Apr 15, 2008 | 06:46 AM
calvinhuh's Avatar
hmmm yea.. i bought the strup headers
used the cel eliminator and put it on the s pipe..
im wondering if i was to use a scanner would i be able to check if there is any leak in the o2 sensor on my header.?
Old Apr 15, 2008 | 06:58 AM
AcidDrop's Avatar
well if you messed up the tread on the sensor then be prepared to buy a new one or just get a pick and pick out the tiny medal pieces around the tread and try rebolting it.
Old Apr 15, 2008 | 07:01 AM
calvinhuh's Avatar
my friend was telling me to just get him a
2005 tc universal 4 wire o2 sensor with no connector
and he can use solder to make a new one.
would that 05 one work?
Old Apr 15, 2008 | 07:05 AM
AcidDrop's Avatar
yeah it's the same thing as long as the same colors are solder together. also i hope you didn't mess up the tread inside the header cause then you have to drill a new tread, if not then say goodbye to them.
Old Apr 16, 2008 | 06:27 PM
calvinhuh's Avatar
im not sure if this happens to people also...
but my
cel just turned off
i didnt even use a scanner to reset it or anything.
does this stil mean that i have a leak in my o2 sensor???
Old Apr 16, 2008 | 06:31 PM
emptystreets130's Avatar
Even though it turned off, the code is still stored in the computer. It doesn't mean it really went away or stopped on it's own. There is still a leak. The ecu probably compensated for the leakage by adjusting the air/fuel mixture. You car might be running rich now or should of been running rich.
Old Apr 16, 2008 | 08:40 PM
silverstreaktc's Avatar
get a tap and die set and redo those threads!
Old Apr 21, 2008 | 07:08 PM
sciontc21's Avatar
yeah i believe so
Old Apr 21, 2008 | 07:25 PM
06siHubby's Avatar
You could just buy some pro seal type sealent and put in around where the leak is and let it seal. Make sure you use high temp sealent though.
Old Apr 22, 2008 | 02:01 AM
calvinhuh's Avatar
hmmmm i used
black silicon.
i duuno if i dried it enough
cuase after about 2 hours
i drove my car on freeway for like 2 hours
more then 80% of silicon is gone. lol haha
Old Apr 22, 2008 | 02:02 AM
^^^ that's not high temp. Either the copper or the rtv red will do.
Jordly221
Feb 13, 2019 05:29 PM
Miqmiqmiq
Apr 16, 2016 02:34 AM
daniinpitt
Apr 4, 2015 08:07 PM
AdmirN
Jan 5, 2015 10:19 PM
ScionRo
Jan 2, 2015 07:54 PM
