View Full Version : shaking
SFScionGuy
04-17-2008, 10:35 PM
Need some help here folks.
I noticed when I'm at a stop light and about 7/10 times I will be stopped and my car seems to shake. I want to say it's coming from the front of the car (engine) but I'm really not sure. I also hear like something is tapping something else when I'm stopped causing a sound I can hear like something is vibrating. Anyone have any idea of what it could be?
jct
04-17-2008, 11:00 PM
its most likely the stock air intake box it'll go away if you replace it with a aftermarket intake system... :?
jurassic1
04-18-2008, 12:16 AM
Better check your belts. If the whole car shakes then def something's up w/ the engine. Did you replace your pulleys?
06TurboCharged
04-26-2008, 03:24 PM
Dude.. i have the same freakin problem. it is embarrassing as hell if someone is in the car.. It just starts shaking and i tried to put it into nuetral or in gear to get it to stop shaking. Does anyone know why it does that.
SFScionGuy
04-27-2008, 05:21 PM
I'm not sure, I looked at the belt area, tested it while my ac was on or off. it didn't really matter. i put my e-brake on, while it was in drive in my garage (do this at your own cost) and then go under my car to see where the noise was coming from. i noticed it was near the belts or seemed to be.. other than that i have know idea what the problem is. it's no a horrible ___ shaking, it's more of like something is shaking and then rattling something else. i did clean my MAF sensor and changed my air filter and the shaking did go down and is not there as much.
