Kumho Ectsa ASX 225/60VR15 Questions
Old Apr 19, 2008 | 10:30 AM
GForce's Avatar
Default Kumho Ectsa ASX 225/60VR15 Questions
Hi everyone I have a set of Kumho Ectsa Spt tires on my Xa which I love but they are now discontinued. I'm thinking of replacing them with Ectsa Asx 225/60VR15 tires. Will I encounter any rubbing issues? Any feeling about these tires? Thank You
Old Apr 19, 2008 | 06:20 PM
boxedfish's Avatar
Just lto let you know, that tire you want to run is almost two inches taller then stock. I really think your going to run into a lot of rubbing. I could be wrong but, the math don't lie. " WH+D=a/25.4= inch"
Old Apr 19, 2008 | 07:35 PM
GForce's Avatar
I'm a bit confused the stock tires are 185 15 60 so how are 225 15 60 any taller.? Aren't they just wider?
Old Apr 19, 2008 | 08:58 PM
BayAreaScion's Avatar
yup wider, not taller, 65 or 70 would be taller, but I also don't think a 225 will fit a stock rim. The rim would probably need to be 7-71/2 or 8 if I'm not mistaken
Old Apr 20, 2008 | 12:09 AM
boxedfish's Avatar
It would fit the wheel just fine. The differance is in the overall hiegth. The 185/60/15 is 23.74" inchs tall and the 225/60/15 is 25.63" inchs tall. The 225/50/15 is 23.85" inchs tall and this is why I suggest the 50 over 60. I would just hate to see anyone buy something that won't work like they would want it to. The series number is a percentage of the width and not a set hieght.
Old Apr 20, 2008 | 03:19 PM
Boxer_Rebellion's Avatar
WAY too big. 225/50 would work, but there's no real point in going that wide. 205/50 or 205/55 are a good choice.
Old Apr 21, 2008 | 04:42 PM
archangel's Avatar
http://www.miata.net/garage/tirecalc.html
Here you can check it out for yourself on this site and compare the stock tire with the one you want to run, I am running 205/55/15 and it rubs in the back, but I am on an after market rim and I think the offset is what is causing the issue, I think on a stock rim I would have been fine
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
