View Full Version : Tc Big Brake conversion
sodathustla
04-20-2008, 02:48 PM
I was wondering if any other toyota calipers would fit the TC. Because willowwoods are way over-rated IMO and I think it would be sweet to put on some 4 pistons from a celica maybe.... Let me know if any of yall have done this....
Mari0
04-20-2008, 02:49 PM
the trd big brake kit for celica fits the scion. Btw I am sure there are tons of topics on that. You should try and search.
1_kLEan_tC
04-20-2008, 02:50 PM
You can get the stoptech/TRD kit from the celica or rotora kit...
Also its wilwood not willowwoods...
torqueTc
04-20-2008, 07:31 PM
Wilwoods are NOT over-rated. They are acctually going to come in way cheaper than most other BBK's. I have the stoptech kit for my car.
Its kinda like this (from my personal research) that the BBK's kinda go like this
1) stoptech/trd and endless at about $2000
2) rotora is about $1500
3)wilwoods are $1000
at the end of the day, most BBK's are going to really be the same, but you do also get what you pay for.
How much do you have to put out for a BBK??. The brake setup for the tC is near identical to the newer gen celica, so there is no reason to put celi brakes on your tc.
1_kLEan_tC
04-20-2008, 09:12 PM
Endless is more like 3k...
Also you can buy a 6piston rotora kit for like 3k too...
Zebman
04-20-2008, 09:36 PM
How often are you tracking? Because if you aren't, the only benefit you're getting of a BBK is slightly reduced acceleration and overall mileage. So just pick which one fits your budget.
1_kLEan_tC
04-20-2008, 09:46 PM
How do you figure you lose acceleration and mileage.....
Zebman
04-21-2008, 12:13 AM
Rotational weight is a lot more effective at reducing both those than having additional weight in the car. And the only thing that a BBK does for performance is reduce brake fade, which you shouldn't be experiencing on the street within legal boundaries.
It looks ballin' though, don't get me wrong. I wanted the Wilwood, but never fit it into my budget.
silverstreaktc
04-21-2008, 12:44 AM
Ive heard (and agree) that unless you have 300whp and tracking the car, there's no reason why a set of slotted (or drilled) rotors and upgraded pads/lines shouldn't do the trick.
2fast4you
04-23-2008, 04:27 AM
That's partially correct... you don't need 300whp to use a pad/rotor upgrade, it is extremely effective with stock hp as well. But get slotted only... drilled is for fashion; there isn't a noticeable weight reduction and you increase the risk of your rotors cracking if you like to abuse your brakes.
As for BBK, Wilwoods are not over rated, but BBKs for the street are. If you don't have sticky tires and don't intend to track your car, they're for nothing more than show points.
