What are all your preferences to motor oil?
Old Apr 22, 2008 | 04:05 PM
Invertalon's Avatar
Default What are all your preferences to motor oil?
I am just curious to what every seems to be using as the "blood" in your xB's.
Currently I am using whatever 5W20 oil the dealer put in there, but next Tuesday I am doing my change and have my Mobile 1 0W20 ready to go in. Can't wait!
I would of proffered to try Pennzoil Platinum 0W20 but is really impossible to find unless I order online, so I will just go with Mobile 1 and see how it does.
What are all you guys using?
Old Apr 22, 2008 | 04:30 PM
ExplorHer's Avatar
I hven't changed my oil yet, but I'm a big fan of Amsoil's products.
Old Apr 22, 2008 | 04:38 PM
MaxBoost925's Avatar
I like Mobil1 synthetic stuff.
My first oil change was at the dealer with Havoline 5w-20.
Old Apr 22, 2008 | 05:13 PM
XD40tC's Avatar
Royal Purple 5w20 right now. Its runnin great!
Old Apr 22, 2008 | 05:41 PM
rockthebeef's Avatar
I did the free 5k at the dealer and they scratched my wheels a little while prying off the center caps.
I'm going to do the 10k myself. I'd rather spend half a day at home than going to the dealer to watch them butcher my car again.
I'm going with Mobil 1 0w20 and probably a toyota filter. Anybody know if the TRD oil filter is worth it? I'd probably go for a mobil 1 filter for that price.
Old Apr 22, 2008 | 05:46 PM
AAG's Avatar
AAG
DeepSouth Scions
Currently using castrol dino 5w-20 but I plan to switch to either German Castrol Synthetic or Amsoil on my next oil change at 10k.
Old Apr 22, 2008 | 08:02 PM
wrczx3's Avatar
People tend to get very defensive about their choice of oil and like to think that they are using the best stuff made. Honestly, I highly doubt that in a street driven economy car we would ever see any differnece between any oils. Just use something that passes the proper standars and change ot often enough with a decent filter and you will ot have a problem. I personally prefer sythetics only because I like the extended drain intervals. I use Walmarts own oil called Supertech. It is 100% sythetic and passes all the requirements and it is really cheap.
In my two stroke ATV I only use Motul 100% ester based sythetic.
Old Apr 22, 2008 | 08:38 PM
stuckpig9's Avatar
Mobil 1 Synthetic 5w-20
Old Apr 22, 2008 | 08:40 PM
InfiniteVisi0n's Avatar
x2 better than Royal Purple
Old Apr 22, 2008 | 09:33 PM
XbbbbBox's Avatar
Default Oil
I use Amsoil for the long drain intervals. I use a Wix filter with filter Magnets and change the oil every 20,000 miles and the oil filter every 10,000 miles.
Amsoil says there oil is good for up to 25,000 miles.
Before everyone flames me I have been doing this for years - my last vehicle had over 335,000 and did burn a drop of oil.
Old Apr 22, 2008 | 09:54 PM
Turbo4door's Avatar
My first oil change I used 0w20 Toyota synthetic. When I can find a close source for 0w20 Mobile 1, that is probably what I'll go with.
Anyone know who actually makes Toyota synthetic oil?
Dan.
Old Apr 22, 2008 | 10:01 PM
coryjames's Avatar
i went with 5w30 royal purple the best stuff made
Old Apr 22, 2008 | 11:52 PM
Invertalon's Avatar
Why aren't you guys running synthetic not running 0W20?
Old Apr 23, 2008 | 01:20 AM
I'm gonna run Mobile 1 5w-20 synthetic when I go supercharged. I want a thicker oil for more protection.
Old Apr 23, 2008 | 01:55 AM
Invertalon's Avatar
It's not thicker though...
0W-20 and 5W-20 are same weight at operating temp. 0W will just be thinner for cold starts, which is something you WANT the most of. No oil made is thin enough to properly lubricate an engine at startup currently.
Here is all the information you'd ever need to know about oil thickness/grades.
http://ferrarichat.com/forum/faq.php...tor_oil_basics
Basically to sum it all up, go to 0W if you can no matter what. As the car gets older the only variable you should be changing is from 0W20 to 0W30 to 0W40, etc...
So if you can, run the thinnest "cold" weight you can. Its still way to thick to lubricate and protect the engine at startup but will be MUCH better for our engines.
Old Apr 23, 2008 | 02:04 AM
Steventc07's Avatar
I have tC but as we all know we have the same engine, I use Castrol Syntec 5w20
Old Apr 23, 2008 | 04:09 AM
generem's Avatar
Havent done the 1st oil change yet but was planning on running the mobil1 0-20w. But after reading wrczx3 reply.. Im gonna do a bit of homework to see if there would be a difference in different brands
Old Apr 23, 2008 | 04:22 AM
ravenfox's Avatar
Im going for the first 2 oil changes with the dealer. 1st one will be b4 I go on vacation or even while im one vacation, either way, b4 1500 miles..The 2nd will be done at 4500 miles..THEN, Im going with 0w-20 Amsoil.I will have to order it on-line as I cant find it here..probably amsoil oil filters as well..Just in time for winter driving.Ill be riding the bike all summer...AJ
Old Apr 23, 2008 | 04:35 AM
Invertalon's Avatar
Yeah, im a big time "browser" over at bobistheoilguy.com forums, and it seems to be that the "fan favorite" out of all the synthetics are pennzoil platinum, returning what seem to be the best "UOA's", which are bascially oil tests to determine specific metal wear.
I was going to try the PP, but I can't find 0W20 anywhere around here, just Mobile 1.
However, any synthetic will be just fine especially with the "short" 5k intervals most of us will be doing. If we really pushed our oil, then it would be important I guess to try to scavenge the absolute best oil. haha
Old Apr 24, 2008 | 01:37 AM
al74dart's Avatar
I'm not wanting to get into a debate on good or bad, but I am using Mobil 1 synthetic 5W-30 regular not the extended milage stuff. I am also using the PureOne PL14477 oil filters. I live in Southern Arizona 40 miles from the Mexican border and like the extra protection the heaver weight oil provides.
