Mysterious damage to grab handle on the hatch
Old Apr 22, 2008 | 07:48 PM
Shan14's Avatar
Default Mysterious damage to grab handle on the hatch
I was looking closely at my car yesterday, and there are like two long and shallow cuts into the paint immediately to the left of the grab handle. Seems like someone tried to break it off with a flathead but gave up?
Is this a way to gain access to the hatch and try to break into the box?
Old Apr 22, 2008 | 08:00 PM
burstaneurysm's Avatar
You mean the hatch handle? Beats me.
Old Apr 22, 2008 | 08:05 PM
draxcaliber's Avatar
yes, ofcourse, for every locking and security measure, there is a way to defeat it. people pick and disable locks all the time. though most of the time, they'll just smash the glass.
Old Apr 22, 2008 | 09:16 PM
stew32's Avatar
If they weren't there before and you don't know how they got there, then someone must have been trying to break in. Are you the first owner? If not, the previous owner may have broken the hatch handle and made the scratches in the process of replacing it and you just never noticed until now.
Old Apr 22, 2008 | 10:29 PM
Shan14's Avatar
No, I'm the first owner. Sometimes I wonder if I should just drop the cargo cover when I've got nothing back there.
Old Apr 22, 2008 | 10:54 PM
dmpsk8's Avatar
is any work done to your ride at all? its random that they would try and break in w/o some type of "tuner" sign
Old Apr 23, 2008 | 12:13 AM
Shan14's Avatar
I had the front bumper components replaced a couple months ago, but the back should have been left untouched. It's possible that the shop left my car outside overnight (not the best neighborhood).
Old Apr 23, 2008 | 12:27 AM
can you post a pic
Old Apr 23, 2008 | 01:09 AM
Shan14's Avatar
Old Apr 23, 2008 | 12:08 PM
blimey's Avatar
Is your handle loose? I have the same mark on mine(only much smaller)The nut on the backside of the handle had backed off.The handle was moving both when opening and as I drove causing it to hit that spot.Those hadles are so brittle that I would think it would break if someone pried on it.
Old Apr 24, 2008 | 12:37 AM
CBSIMONSEZ's Avatar
^+1
If someone were to try and get in there with a flatblade the plastic would at least be scratched. Your plastic housing for the trunk release switch is loose.
The fix is easy. Remove the inner trunk liner and tighten the 2 10MM nuts on the back, but dont over tighten.
Old Apr 24, 2008 | 12:46 AM
Shan14's Avatar
Thanks for the tips, guys.
Hatch liner removal?: nm https://www.scionlife.com/forums/vie...ighlight=hatch
Old Apr 26, 2008 | 09:14 PM
MR_LUV's Avatar
Administrator
Administrator
The Hatch handle is notoriously weak and subject of many previous posts:
https://www.scionlife.com/forums/vie...t=hatch+handle
IF someone was prying on it, it would already be off. So the most likely scenerio is that it was
loose at one time and what you see is the chafing of the handle against the paint.
IF you do not have a trim panel removal tool, you can use a pair of dikes if you are careful:
https://www.scionlife.com/forums/vie...231&highlight=
MR LUV
Old Apr 28, 2008 | 01:18 AM
dmpsk8's Avatar
bro i know exactly what that is. mine did the same thing. scions cheapo paint tends to wear off quick in that particular area. Hit it with touch up some it doesn't keep going
https://www.scionlife.com/forums/vie...chipping+hatch
elwaylite
9
May 15, 2020 07:27 PM
Scionxa180
Sep 24, 2015 03:51 AM
Threequalseven
Aug 26, 2015 04:24 PM
TOOSLOW
Jul 25, 2015 05:19 PM
excb7
Jul 19, 2015 11:17 PM
