Scion XB Sine-Vip Type-1 Body Kit
Old Apr 22, 2008 | 11:18 PM
TuningIsLife's Avatar
Default Scion XB Sine-Vip Type-1 Body Kit
So I was flipping through my Super Street the other day and came across this body kit from a site called GroundDynamics.
They call it a 04-06 Scion XB Sine-Vip Type-1
Anyone seen, used or heard about this? It almost looks like a knock off Noblesse kit.
It is going for a total of $1045 for all 4 pieces.
Old Apr 22, 2008 | 11:24 PM
dminner's Avatar
Yeah, there are 2 other companies (that I know of) that are also selling replica Noblesse kits now.
Old Apr 23, 2008 | 01:02 AM
ROBs-xB's Avatar
Thats because it is a knockoff Noblesse kit,
what wheels are those anyways?
Old Apr 23, 2008 | 08:29 PM
ogerdgonz's Avatar
There is better pricing available on it also.
Old Apr 23, 2008 | 08:51 PM
burstaneurysm's Avatar
Just putting it out there, but the real Noblesse kit is about $800 more than this one. Of course, the initial cost is cheaper, but I'd wonder how much more the knockoff will actually end up costing considering the inevitable bodywork that will be needed to get it to fit.
Old Apr 23, 2008 | 11:27 PM
ROBs-xB's Avatar
All I have to say is that it does take a bit of work (alot )
I did all the body work on mine to make it fit, its the m2m kit,
and it still isn't 100% perfect, after all the 100 plus hours I put
into it, it ended up looking like a high 8/10. (check profile for pics)
It was an advantage for me to get the knockoff because I work at a shop,
but for those of you who have no body work experience, I say save
your pennies because its going to cost you.
Just a bit of info. a personal reference tells me that the Genuine Noblesse
kit isn't exactly a perfect fit, it to needs work.
Old Apr 24, 2008 | 12:59 AM
Originally Posted by onetongarage
To fit the Noblesse bB bodykit to the USDM xB you will need to remove the front and rear bumper core supports, and the front toe hook bracket (easily removed with 2 bolts). The front bumper has a 2.5" square hole for the JDM bB's toe hook bracket, and this will need to be filled. A small portion of the back side of the front bumper will also need very minor trimming to clear the USDM xB's air conditioning line (this can be done in about 5 minutes). There is no exhaust cut-out on the rear bumper so that you may cut it to fit whatever exhaust setup you would like to run (such as the dual exhaust seen below), or leave it as is for a smooth, stealth appearance. The bodykit will bolt right on to factory mounting points, and comes with a black gel coat finish ready for primer and paint.
One Ton Garage is THE authorized Noblesse dealer in the states. Just check the Noblesse site.
Full bodykit (includes front and rear bumpers and both side skirts)
$1870.00
Old Apr 24, 2008 | 01:57 AM
dmpsk8's Avatar
rob, ur ride is lookin good these days bro. love the kit
Old Apr 24, 2008 | 02:00 AM
faux_ghost's Avatar
its all the same pix, same car, same kit
Old Apr 24, 2008 | 02:59 AM
jdmrace1's Avatar
looking good
Old Apr 24, 2008 | 04:57 AM
Pretty much any body kit is going to need work to fit, but I would rather get something that will start closer and do less work on it.
Old Apr 24, 2008 | 05:03 AM
Big_Bird's Avatar
Boooooo on noblesse knock-offs
Old Apr 24, 2008 | 05:05 AM
1_kLEan_tC's Avatar
this kit looks clean....
Old Apr 24, 2008 | 05:08 AM
hotweelz4me's Avatar
sorta off topic, but the pic is of a bB, so I can assume it is from Japan, but look behind the box and see the Silverado!
Old Apr 24, 2008 | 01:53 PM
ogerdgonz's Avatar
The knock off is actually a closer fit than the authentic Noblesse kit. The Noblesse kit is for the NCP 30 bB or the first gen with the smaller crash bars.
Old Apr 24, 2008 | 02:39 PM
^ That's kinda ironic.
Old Apr 24, 2008 | 07:21 PM
chris59's Avatar
i think black rims will look better than silver for white car. White rims might look nice too.
Old Apr 24, 2008 | 07:40 PM
Am I suddenly in a different thread?
Old Apr 25, 2008 | 12:24 AM
shrug
so where else lists a knock off noblesse kit?
Old Apr 25, 2008 | 12:26 AM
ROBs-xB's Avatar
back on topic peeps...
Anyways thanks for all the kind words.
As it was stated above, these knockoff's are a closer fit
than the real deal, they have the rear plate section shaved,
and are only about 1/2-1 inch off from a perfect fit, Knockoff
or not, these Noblesse kits fit extremely tight.
as someone mentioned about the reinforcement beams, it doesn't
matter what kit you get, if its Japanese specs, IT WILL NOT FIT.
reinforcement beams (crash bars) must be removed. Or import
the bB beams. I made my own front beam, safety first! the rear
beam didn't need to be removed.
amart
Scion xD Aero & Exterior
Dec 23, 2014 12:06 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
ScionLife Editor
Nov 28, 2014 11:10 PM
eric_m
21
Dec 15, 2003 09:51 PM
roo
18
Oct 8, 2003 05:04 AM
