cf hood install question?
Old Apr 26, 2008 | 01:31 PM
svencarlson07's Avatar
Default cf hood install question?
hey just got my sibon vs2 hood and going to install it just had a quick question is there any specific way to do this or is simply unbolt stock hood and bolt on new hood and do the window washer sprayers..do those just pop right out? thanks
Old Apr 26, 2008 | 01:44 PM
JOEinSD's Avatar
take off your spray nozzles. squeeze them from the underside and they push up/out. you can even use a flathead and press each side of the clips/tabs. do what you want with your hose. unbolt the hood. bolt the new one on but keep it loose first. adjust the gaps. tighten. you're done. should take 10 mins with a buddy, which i recommend having.
Old Apr 26, 2008 | 01:54 PM
alright thanks man just want i wanted to kno
Old Apr 26, 2008 | 01:59 PM
JOEinSD's Avatar
and just so you don't scratch your car, put some cloth down near the points of the hood (near the windshield).
Old Apr 26, 2008 | 02:25 PM
indyTC's Avatar
10 minutes hahahha....
Old Apr 26, 2008 | 02:30 PM
JOEinSD's Avatar
if you know what you're doing. yes.
trust me. i just switched hoods 3 times in the past week.
Old Apr 26, 2008 | 02:49 PM
Dilirious's Avatar
LOL easier said then done, sat down looking at the hood off on my car for like a day trying to get out the nozzle. alot easier now that i know how to take em off
Also the nozzles may not fit so you may have to file them down.
-Jeremy
Old Apr 26, 2008 | 04:20 PM
okay i got it on but it doesnt sit flush in the front and idk how to adjust it to make the front go lower...any help?
Old Apr 26, 2008 | 08:37 PM
Dr_Isotope's Avatar
You may need to remove the frontmost pair of hood stoppers (the little rubber guys that thread up and down). I had to, now it sits nice and tight.
Old Apr 26, 2008 | 09:11 PM
MeatRocket's Avatar
-Jeremy
x2
i have a kaminari hood and tried to install it. nope would not fit right, i tried adjusting and still the same issue. i finnaly got it on it turned out that the stock bolts needed to be changed thats why it would not al;ing correctly. now its perfect i could not use the stock nozzels i had to use smaller ones where the whose attached under neath the nozzle not on the side.
Old Apr 26, 2008 | 09:38 PM
I got it on..needed another washer and the stock screws didn't fit and I had to lower those hood stopper things
wiltonhall
Jun 23, 2025 10:09 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
