HELP!!! PLEASE!!
Old Apr 30, 2008 | 04:52 PM
MrBurrito's Avatar
Default HELP!!! PLEASE!!
i need Help!! i just tried to install my ss clutch line and now my clutch pedal doesn't work! i thought i did it right. PLEASE HELP!
Old Apr 30, 2008 | 05:00 PM
XIEmperorIX's Avatar
What do you mean it doesn't work? Does it go all the way to the floor?
Also did you check your tranny fluid level? You may have lost a lot of fluid when you put on the new clutch line. The only problem I could think of is your fluid might be to low.
Old Apr 30, 2008 | 05:02 PM
adamf's Avatar
You need to bleed the air out of the clutch line before it will function. This is related to the brake fluid, not the tranny fluid.
Old Apr 30, 2008 | 05:04 PM
MrBurrito's Avatar
can u tell me how
Old Apr 30, 2008 | 05:19 PM
^ whoops my bad haha I meant brake fluid..knew something didn't sound right..
Anyway here is a link to something that might help http://www.miata.net/garage/clutch_bleed.html
The process in the above link was performed on a miata but the process itself is the same, the only difference is going to be the location of bleeder valve.
Hope this helps!
Old Apr 30, 2008 | 05:23 PM
MrBurrito's Avatar
i did it thanks now i can go to school
