Let me guess...someone has asked this question before
well, i just signed up and as my first act i am going to prepare to be flamed by the jaded-hatingnewbies-scionlife old-time crowd.
here goes: (and i'm sure everyone will tell me it's a stupid question and that i should use the search function--which i did multiple times and can't find the answer).
i want to put new wheels/tires on my 2008 tc.
the best choices seem to be in the 35mm offset (versus the stock 45mm)
i'm thinking about 8 or 8.5" width.
19 or 18 inches diameter.
i have trd springs.
and now, finally
, the question:
what will i need as far as wheel studs and/or bolts to make the 35mm offset work? if the factory studs are set up for the 45mm offset, do i need new (longer) studs?
any help would be appreciated from the experienced crowd (which i'm sure is doing this right now:
i have trd springs.
and now, finally
i guess you do not know what "offset" of a wheel is.
it got nothing to do with your studs or bolt. it is the "the distance from the mounting pad to the centerline of the wheel."
you should read ou on this
https://www.scionlife.com/forums/viewtopic.php?t=98863
i have 35 offset wheel and don't need longer studs.
offset is simply the distance from the center to the part that's secured onto the studs. it's only when you use 10mm+ spacers that you need new studs.
edit: i'm just going to throw this link in
http://www.zilvia.net/f/showthread.php?t=166626
Originally Posted by supraman21
No, you don't need longer studs. 8.5 inch width with a +35mm offset might stick out pass the fender a little much.
go 19x8.5 et+35 = sexy
eric_m
52
Jan 17, 2019 05:50 AM
2002cbr600f4i
Dec 6, 2003 02:01 AM
