Easy street air ride system now taking preorders!!!
Old May 3, 2008 | 05:16 PM
sybertiger111's Avatar
Default Easy street air ride system now taking preorders!!!
Ok here we go.... Scionpro will be the first distributor for the Gen 2 fully digital air ride kit from Easy Street! Available first week in May. Pictures have already been posted in another thread. It goes as high as a monster truck and as low as a bug! Ready for pricing????? ...... are you sure ..... drum roll please...... Bada Bing>>>>> 2199.00 complete ! thats everything, tank, valves, hose, fittings, pump, including the digital set up. Shipping averages about 80 to 120. This is an exclusive intro offer from www.Scionpro.com Pricing will jump to 2399 for the complete set up shortly. I will have it up on the site by Monday to take orders. I have 5 kits initially reserved. Get your pre order in now to www.steve@scionpro.com. I just need your info no deposits.
Old May 4, 2008 | 06:43 PM
detroitbassxb's Avatar
Amazing kit at a great price! You guys should jump on this!
Old May 4, 2008 | 08:36 PM
if anyones ganna pick up this kit tell them Luna referred you on checkout!!! its a great kit ill see if i can find some pics of this!!!
Old May 4, 2008 | 08:38 PM
[/QUOTE]
[/QUOTE]
Old May 4, 2008 | 08:39 PM
Oh and on top of all this awesome kit ness, its a digital control system that like an extra $600 for Free!!! tell em Luna sent ya!!
Old May 4, 2008 | 10:23 PM
Might wanna double check if it comes with that pancake tank or not. I know they did that special for my car, not sure if all of the kits are coming with that tank.
Old May 4, 2008 | 10:43 PM
coryjames's Avatar
that car is to high still
Old May 5, 2008 | 01:34 AM
Are you serious? It's less than 5" off the ground
Old May 5, 2008 | 01:39 AM
dredge38's Avatar
it looks like it goes higher then it does lower. Im 3 inches of the ground with no air . That is a pretty good price for a digital air ride set up though.
Old May 5, 2008 | 02:28 AM
coryjames's Avatar
i drive around at less then 5 inches off the ground lol my frame rails on my unibody are 3.25 inches off the ground as i drive around if you want to get low get ksports and put bags on them you will be lower then g ws ratings you know thats low
Old May 5, 2008 | 03:43 AM
Sorry man, it def goes lower than yours does.
Old May 5, 2008 | 03:52 AM
redline8k's Avatar
im interested in knowing what tank it comes with as well.
also if I run 20x8.5s with 45mm offset will it tuck lip. I know detritbassxb is running 19s with a 40mm offset. I just wondering is the 5mm difference in offset and inch difference in height will make it work. I dont care if I have to roll the fenders....thanks
coryjames, you may be lower, but not all of us can stay that way all the time. I cant roll like that here in Chicago. Ill get eaten by a pothole...
Old May 5, 2008 | 04:19 AM
ive olny seen two air ride systems that were done and they both were with 19" rims @ 40mm offset. Not sure what tank it comes with.....contact steve@scionpro.com. for more information!!!
Old May 5, 2008 | 02:15 PM
I can't imagine you will have a problem tucking. The inch difference shouldn't make a difference at all since you'll most likely make up the difference in tire size. You just need to be careful of tire width. I used 205 tire width. Anything much wider than that and it wouldn't have tucked. If you can find a 205/30/20 tire, it will probably tuck without a problem.
Old May 5, 2008 | 02:38 PM
just found out you can have a barrel or pancake tank youyr choice!! -luna
Old May 5, 2008 | 03:11 PM
redline8k's Avatar
negitive on the 205/30/20s', I did a quick search and nothing. what size are you running on the 19's (205/?)? Also how much are your tires "streched"? I think if I went with the 20 Id have to go 225/30 or 225/35's. I think with the added offset difference and some fender rolling I could pull it off. But can you post close up of the wheel and fender with the car dumped so I can see the clearences.
thanks
-nick
Old May 5, 2008 | 09:11 PM
Sonicaftermath's Avatar
awesome... i want to put 22's on mine, i'd have to drive with the bags up and roll the fenders for tucking, but 22's on an Xb2... sick.
Old May 6, 2008 | 03:35 AM
redline8k's Avatar
email sent to scion pro...
-nick
Old May 6, 2008 | 08:45 AM
eight08customs's Avatar
I have 19x9s +35 in the rear. would have had a fat lip if the rims wasnt full faced. tucks well.. and sits flush and still got 1.5 inch on the inisde till it rub the shock.. you can run an 10.5 inch wheel in the rear with some fender rolling.. an 10inch with ease..
The feautre in Siphon on my car.. they didnt let me sit the car to the ground.. thats why the tires are sitting level with the fenders..
Its all about the tire size..
but the 8.5 in the rear will work with ease..
its not as crittical when you have bags.. you pretty much can make it work some how..
Old May 6, 2008 | 01:25 PM
redline8k's Avatar
Im worried mostly about the fronts rubbing when I lower it. Im sure you could fit a small child in the rears. Right now Im more interested in going as low as possible rather than having really wide rims, rims can change once I get confrotable with the system.
Marshall you have another pm.
-nick
