Fitment for 16" x 8" rims
Old May 6, 2008 | 03:34 PM
THansenite's Avatar
Default Fitment for 16" x 8" rims
I am looking at getting some 16" x 8" rims for autocrossing. I want to mount some r compound tires to them for when I hit the track. The rims I am looking at are the 16x8 Rota Slipstreams with a 48mm offset. Does anyone know if these will work on the tC? Thanks.
Old May 6, 2008 | 04:25 PM
PAUK's Avatar
test fit it
Old May 6, 2008 | 05:38 PM
THansenite's Avatar
While that is an option, I would rather not have to pay for shipping, shipping back if the rims don't fit, restocking fees, and another shipping charge for rims that fit.
I just wanted to see if anyone had tested these rims out on their cars so that I could be sure they fit before I order them.
Old May 6, 2008 | 08:48 PM
PAUK's Avatar
are u worried that it would be too small or too wide?
Old May 6, 2008 | 08:52 PM
nebster's Avatar
tony if you want to keep the stock depth of the wheel go with a
stock will sit approximately 43.9mm from the hub if you want the 8" wide to stick the same distance you need an offset of 57.7 mm. while this is not possible keep in mind having a offset of 48mm will stick the wheel out approximately 10mm further towards the outside of your car from your stock split 6 spoke wheel, not sure about the enkei wheels you have but i can look it up. SO if you really want to see take a piece of cardboard and cut it so its 10mm wide (1/2") then put it on your stock wheel (split 6) and see if you have any clearance issues. that should answer your questions.
Old May 6, 2008 | 09:25 PM
THansenite's Avatar
I think I could manage with an additional 10mm from the hub. I'll probably need to roll the fenders anyway, especially with coilovers in the near future.
eujin
Feb 23, 2016 01:18 AM
axB
Sep 18, 2015 06:11 AM
peruviann
Sep 14, 2015 06:35 AM
Robineileen324
Sep 14, 2015 06:21 AM
JZA70
Sep 12, 2015 09:37 PM
