Any tricks to make my back end drop a little lower
Old May 7, 2008 | 08:40 PM
Nastos's Avatar
Default Any tricks to make my back end drop a little lower
i have skunk2 springs and im not really happy with the drop in the back any ideas on making it a bit lower? the front looks good but the back could use another inch
Old May 7, 2008 | 08:49 PM
Thumps's Avatar
5 or 6 50lb bags of concrete mix in the cargo area.
Might have a slight effect on acceleration and braking performance though.
Old May 7, 2008 | 08:51 PM
Nastos's Avatar
lol
Old May 7, 2008 | 10:37 PM
sizzlinscion's Avatar
get new springs
Old May 7, 2008 | 10:49 PM
CDogbert's Avatar
However, you'll be prepared if you're ever stranded in the woods and need a hard surface for things like playing a rousing game of four square or hopskotch.
Old May 8, 2008 | 01:52 AM
Sciond's Avatar
use the echo rear shocks....and use Monroe's
Old May 8, 2008 | 01:59 AM
Nastos's Avatar
whats monroes? struts?
Old May 8, 2008 | 02:21 AM
Sciond's Avatar
Monroe Sensatrac rear shocxs
Old May 8, 2008 | 04:46 AM
burstaneurysm's Avatar
The rear shocks have no effect on the rear ride height, only the front.
Old May 8, 2008 | 05:23 AM
Nastos's Avatar
yeah if i was gonna throw down all that money id just get some s techs... i didnt know if there were some minor suspension mods i could do to the stockies to make em a lil lower... probably just see if some one who is too low wants to trade springs
Old May 8, 2008 | 08:54 AM
bB2NER's Avatar
Music City Scions
Only way to lower your current springs would be to add some spring clamps. Not sure if you'd have enough space between the coils tho to fit them in tho. You would basically clamp 2 of the coils tight together lowering the ride height more.
Old May 8, 2008 | 01:53 PM
Boxer_Rebellion's Avatar
Actually that is incorrect. Check the Sensatrac threads on this. The difference in gas pressure in the stock shocks actually raise the height up about 1/4" over the monroe's design. There have been before and after shots to illustrate the difference, and I saw this on my own car.
Old May 8, 2008 | 02:13 PM
Nastos's Avatar
but how would that change the weight of the car resting on the springs... i have heard alot that shock swap wont change ride height bc its all in the springs
Old May 8, 2008 | 02:32 PM
Hmm... I was having an issue the other day and swapped my Monroes with OEMs... the ride height didn't change at all.
In fact, I even lowered it just on the spring and even that was only slightly lower.
Old May 8, 2008 | 02:33 PM
Plus, if he's looking for an extra inch in back, it might be worth it to just get new springs - like the DF210s.
Or toss a heavy sub box in the hatch.
Old May 8, 2008 | 02:40 PM
CarbonXe's Avatar
Move the battery to the back .
Old May 8, 2008 | 06:56 PM
Nastos's Avatar
lol i was thinking about getting an extremely heavy system
Old May 8, 2008 | 08:03 PM
CarbonXe's Avatar
150-200 lbs added to the back should be enough for a 4-6mm drop.
Old May 8, 2008 | 08:12 PM
Nastos's Avatar
so roughly one dead body?
Old May 8, 2008 | 08:14 PM
CarbonXe's Avatar
If you feel like putting up with the smell, sure.
