scionbrakes
05-12-2008, 09:50 PM
Since we couldn't find a good post about brake upgrade options for the TC, we decided to post one up.
First, the TC has the following brakes:
Front: 2000+ Toyota Celica
Rear: 2000-2006 Toyota Camry
What does this mean to you?
If you are just daily driving your vehicle and do not care about performance, then nothing. However, if you are on this forum then you probably don't fall into this category.
Most likely you want more brake performance: strong initial bite, good rotor wear and less dust. Therefore, depending on what you do with the car, there is the right brake pad for you.
We have broken up the pads into 3 different categories below:
For high performance street driving and occasional autoX:
Hawk HPS (front only)
SP Performance Street Plus (front and rear)
EBC Greenstuff (front and rear)
Axxis Ultimate and Deluxe
For maximum streetable performance (autoX and Track events with street tires):
Hawk HP+ (front only)
Porterfield R4s (front and rear)
EBC Redstuff (front and rear)
For all out track cars:
Hawk HT-10 (front only)
Porterfield R4 (front / rear)
EBC Yellowstuff (front / rear)
As far as brake rotors, this also depends on how the car is used.
For most applications, the OEM replacement 'blank' rotors are completely adequate. If you upgrade your pads for maximum streetable performance, there are some options to consider.
Brake rotor options:
SP Performance - Slotted rotor with anti-corrosion plating
DBA (Disc Brakes Australia) - Standard slotted and 4000 series with Kangaroo Paw ventilation, rotor temperature indication
Powerslot - High performance slotted rotors
Once you have the pads and rotors sorted out, the last upgrade options you have are the brake lines and brake fluid. When selecting a stainless steel, make sure that they are DOT certified. Stainless steel brake lines resist expansion under high heat and pressure, whereas the stock rubber lines are able to expand.
Stainless Steel Brake Lines:
Techna-fit
Goodridge
High performance brake fluid:
ATE Superblue
Motul RBF 600
More info to follow,
Thanks,
-G[/b]
Techna-fit
Goodridge
ATE Superblue
Motul RBF 600
Thanks,
-G[/b]
