DEI Remote Start still require immobilizer chip?
Old May 13, 2008 | 02:06 AM
ricexizxgood's Avatar
Default DEI Remote Start still require immobilizer chip?
I was wondering if you would still need the immobilizer chip inside the ignition if the car was started with remote start. Does anyone know?
Old May 13, 2008 | 05:52 AM
O5_TRD_tC's Avatar
yeah, someone posted a bypass so u dont have to use a key.
ill try to find it :D
Old May 13, 2008 | 05:58 AM
2_much_tc's Avatar
they have it on amazon.... cheap too and brand new...
Old May 13, 2008 | 06:03 AM
O5_TRD_tC's Avatar
have u experienced using it?
Old May 13, 2008 | 06:14 AM
L337Biker's Avatar
best buy has an 80 dollar module that clones the chip ID so you don't lose a key when you do a remote start. the only issue is best buy has to install the proper software for you vehicle, and the module's not exactly fun to install. if done wrong it can erase all chip IDs from some vehicles.
Old May 13, 2008 | 06:20 AM
Are you talking about this one? http://www.autotoys.com/x/product.php?productid=6181
Old May 13, 2008 | 06:23 AM
2_much_tc's Avatar
http://www.amazon.com/Universal-Immo...0659745&sr=8-9
Old May 13, 2008 | 06:26 AM
L337Biker's Avatar
556u is basically a storage box that you have to stick one of your keys in.. typically the valet key, the xk05 is the module that clones the key ID
you do need two keys to program the xk05 after flashing it
(best buy car audio installer)
Old May 13, 2008 | 06:31 AM
bluaeon's Avatar
yeah unfortunately you need the bypass kit (556u/556uw). i have this kind of alarm in my tc, and i just used my valet key.
Old May 13, 2008 | 06:34 AM
L337Biker's Avatar
as did i originally, but now with that xk05 module you get to keep all of your keys.. it just takes longer to install. luckily.. and not so lucky, the xb2 doesn't have chipped keys, it took a little bit of rigging but while installing my remote start i was able to hot wire it :\
Old May 13, 2008 | 06:38 AM
So after I have the XK05 installed, can I be able to use a copied key (w/o the chip) to drive the car?
What if I installed the 556u using my valet key... can I be able to use a copied key (w/o the chip) to drive the car?
Old May 13, 2008 | 06:40 AM
L337Biker's Avatar
no, the modules only power up when the remote start is activated
Old May 13, 2008 | 06:46 AM
AcidDrop's Avatar
i have the bypass so you can just program the key to it, but i haven't installed it in my car yet because i've been lagging it but when i used to work for a company installing them, it seemed much better than just looking for a really really good place to hide the key. you can buy it online or call this company who is the one that makes it.
http://bypasskit.com/ 1.877.212.8058
PKT2 Toyota Lexus Date Transponder
Override Interface: 2003-07
BYPASSKIT with CLEARCODE
Toyota/Lexus Immobilizer Bypass & Transponder Interface (NO KEY REQUIRED)
that is the one that i have which was the one they recommended me. i got it free so i wouldn't be able to say how much it really is but it's worth it. if you have any questions then just let me know and i'll try to help you out on here.
Old May 13, 2008 | 06:49 AM
O5_TRD_tC's Avatar
wow thanks for all the info, how long does an install usually take?
Old May 13, 2008 | 06:51 AM
L337Biker's Avatar
no problem, it all depends on the installer really... it can take anywhere from 2 and a half hours to all day haha
AcidDrop's Avatar
L337Biker also knows what he is talking about. 05_TRC_tC, installation depends on how well you where which wires are which with a test light, but i'll say a good 2-3 hrs on a well clean job.
Old May 13, 2008 | 06:54 AM
supraman21's Avatar
I have the 556u in my car. I used one of the master key. But when you put it in the casing, you have to clip off the ends of the 556u casing just to get the key to fit. Not sure if you can use the valet key instead of the master. I still think you need some sorta key in the ignition because if i don't put a key in it, i can still get off on first gear and all but the steering wheel locks up and once i hit the brakes, the engine dies.
Old May 13, 2008 | 06:57 AM
L337Biker's Avatar
multimeter ;) air bag horror stories lol
actually best buy had an employee die about 6 months ago due to airbag deployment.. idiot was stripping/testing/popping wires trying to find speaker wires...
probably the biggest pain about the install will be working around the knee airbag. luckily there aren't too many other wires required to make an alarm work in the tc.. door triggers and lock/unlock pulse.. flashing lights if you want, that kinda deal. it's just testing the wires and making sure they're correct
you can use the valet key, that's what was done in mine originally.. it starts the car so it'll start the car w/ the 556u
Old May 13, 2008 | 07:01 AM
AcidDrop's Avatar
here is the wiring diagram for the tC, i have the 1st gen xB and xA as well.
also violet is purple so don't forget about that one.
Year(s): 2005-2007 Make(s): Toyota Model(s): TC
12 Volt (+) 12ga. Red or 16ga. White at ignition harness
Ignition 1 12ga. Blue at same
Ignition 2 16ga. Yellow at same
Ignition 3
Accessory 1 16ga. Gray at same
Accessory 2
Starter 12ga. Black or 16ga. Green, both must be used for remote start
Horn 18ga. White (-) at fuse box, right corner, second connector from the top or at back of fuse box top connector near center of connector
Tachometer
Lights (+) 18ga. Lt. Green left of steering column in 7 pin connector or 18ga. Brown at driver’s kick panel
Lights (-)
Brake Lights
Door 1 18ga. Orange (-) (driver door) at driver’s kick panel
Door 2 18ga. Blue (-) at fuse box top right corner in White connector
Door 3
Door 4
Interior Lights 18ga. Blue (-) at back of fuse box top connector between Black and White wires, can be used as door trigger for all including hatch
Trunk/Hatch 18ga. Violet (-) at driver’s kick panel
Hood Pin
Trunk Release
Lock (switch) 18ga. Red (-) at driver’s kick panel in door harness, White connector
Unlock (switch) 18ga. Pink (-) at same (1 of 2 this color), use with 18ga. White (-) lever wire to override switch lockout
Driver Unlock 18ga. Violet (-) at same, same as disarm key listed below
Arm (key) 18ga. Green (-) at same, also locks doors
Disarm (key) 18ga. Violet (-) at same, unlocks driver door on 1st pulse, unlocks all doors on 2nd pulse, HATCH ONLY OPENS WHEN ALL IS UNLOCKED
Arm Input 18ga. Blue (M) at same in Gray connector
Disarm Input 1 18ga. Pink (M) at same
Disarm Input 2 18ga. White (M) at fuse box in White 18 pin connector, top corner of plug, connector sits between 2 Black connectors
Old May 13, 2008 | 07:02 AM
supraman21's Avatar
Nice... maybe i should change mine out so i can have two master key again. Haha.
