Cargo Net Pics?
Cargo Net Pics?
I just got the Scion cargo net, but I didn't realize I had to drill into my plastic to install it . I'm considering returning it and just not having a net . But, does anybody have some pics of it installed or pics of the actual installation?
I don't have pics
I don't have pics, but I did install it and the cargo cover as well. Just use the templates that come along with it and drill carefully. It looks great and went in easy. Looks just like the factory installed net that came with my camry or my wife's prius.
Super easy job.
Super easy job.
Re: I don't have pics
Super easy job.
Super easy job.
OK, here's a dumb question. I bought an OEM cargo net off ebay and the drill instructions call for 3.5mm and 10mm holes. I just got back from Lowe's, looking for metric drill bits and couldn't find a single one. :?
Closest using the "old" system would be 1/8' and 3/8'. Will these size bits work for the net install? I don't want to drill holes in my new baby, knowing I don't have metric bits and have it all f'd up.
I just finished installing the net so I can answer you completely.
First, the instructions are wrong. I used standard (same problem as you) but I used a special measuring tool to figure out exactly what each drill bit was in mm.
1. the 3.5mm hole actually needed to be about 4.5mm for the end of the screw to screw into the sheet metal (I can't remember what size in standard that was though).
2. Don't even bother setting the 10mm drill stop on the drill bit, just go in untill you go through the sheet metal.
3. If you use a 3/8 drill bit, you will need to round out the hole a bit for the bigger part of the hook to go through the panel. I did it this way, but I think a 1/2" drill bit would work better, I just didn't have one.
In the end, I really don't think it was worth the trouble installing it. If I got another Scion XB, I wouldn't bother.
Thanks for the help.
Don't toss it back up on eBay just yet. You obviously wanted the net, so put it in. I was given the net as a present. Even if you don't use the net, the hooks are great. I plan to hang a bungee cord across mine and use it to hang my groceries on.
Just be aware that the instructions are not exact, but it is not difficult at all to install. I spent more time finding the drill and the drill bits than I did actually installing it.
Also, use the instructions that came with the net, not the one from TRD Sparks. If you print it out from TRD Sparks, the template will not be the exact right size (you can test this with a ruler using the mm scale on the bottom left of the template as it won't match up exactly).
I use mine all the time
I use my cargo net all the time for everything from groceries to notebooks and other stuff that I don't want sliding around in the back.
Take-out is a good example. It holds it well and keeps it from spilling. Eggs and melons are another.
In the attached pouch I keep a multi-tool, screwdrivers, lighter, flashlight and anything else that would rattle in the glove box. I used to hate hearing all that stuff rattling around.
I find it very useful and that is IMHO.
Well, I did end up installing it. Took less than a half hour, and as others have said, the instructions are CLEARLY wrong. I had to gradually increase the drill bit size to a hole that I could screw the T-anchors into by hand with enough resistance to feel it was a permanent install but at the same time not so much resistance that I had to worry about the T-anchor breaking off in my hand. (If that had happened, I would have been majorly ____ed).
I felt a little anxiety drilling that first hole but... once that was over I was like "Let's get this done".
It will be nice to be able to make trips to Trader Joes and not worry about bags with bottles of wine sliding around and crashing into each other.
If you want a bumper protector, this is the one to get. Mine just came in the mail today, and I'm putting it on tomorrow. It's made out of molded plastic/rubber, looks and feels like very high quality to me. It even has a lip to it to so it covers the curve on the bumper. I'll post more pics after it's installed.
Looks good, clean install.
Like others, I am a little disappointed that the pouch area takes up so much (about a quarter, I guess) of the useable "net" area. My primary use will be grocery bags, and as it stands I can only fit about three bags in the net.
airmankevin1
02-14-2018 01:23 PM
carid
04-14-2015 02:18 PM
ExtremeDimensions
12-10-2014 10:01 PM
