LSD
Originally Posted by superjeer
I like to swab door handles of cop cars with it.
Now why would you want to do something like that to my work car?
I've been looking around also for an LSD.
Originally Posted by empleh
are you sure it will fit? the manual transmission in the echo is different than the transmission in the xA/xB.
To me, putting an LSD on an xA is like putting cross-drilled brake rotors on a shopping cart. I'd wait until you had enough horse power to actually make use of one.
If you wanted to road race or autocross your car, you would have been more suited to spend the $15,000 on a used Integra Type-R, which will outhandle almost all other FWD cars on the market, past or present, and comes stock with an LSD, other suspension mods, and almost 100 more horsepower.
got 215-35-18
pretty sticky, but if i go more i loose out too much in tread wear.
most of the time it happens around curves, the weight transfer and turning radius causes the inside to break free easier than i like.
(plus, i've got another hampster or two under the bonnet
hey, I have a couple hamsters in MY.. oh wait you said "BONNET". Nm.
I break loose all the time. but, more importantly.. the echo tranny.. has a lower or higher final drive ratio?
