Anyone know where the horn is located?
Old May 13, 2008 | 12:45 PM
drjohnson36's Avatar
Default Anyone know where the horn is located?
I'm swapping mine and I can't seem to find where it is...
Old May 13, 2008 | 01:17 PM
tCeeder's Avatar
try underneath your steering wheel cover, and the two circle donut looking things behind your front upper grill.
Old May 13, 2008 | 01:51 PM
IntegreS_350's Avatar
When I replaced mine, I didn't touch anything under the actual steering wheel- I just replaced the circular horns under the hood *you can see them through the front grill* and connected them to the wiring that was already there.
Old May 13, 2008 | 09:26 PM
krazyscion's Avatar
little round objects that u can see right behind the bumper.
Old May 13, 2008 | 09:50 PM
Hyghgynx's Avatar
Go to the front of the car and put your ear to the Grille. Have somebody honk the horn.
You'll find them for sure after you regain your hearing!
It's a good idea to remove the horn fuse while installing new horns. (Some horn installs
recommend you disconnect the negative battery cable.) Just remove the fuse and you'll
be ok. (That's what I did.) Everybody is correct on the location of the horns.
excessads
Sep 15, 2015 05:28 PM
user9430961
Sep 15, 2015 03:16 AM
prescottn
Sep 13, 2015 09:04 PM
JZA70
Sep 12, 2015 09:44 PM
BlingSlade
Sep 5, 2015 08:52 AM
