N/A Cam work?!
Old May 14, 2008 | 09:45 PM
ToyoCel's Avatar
Default N/A Cam work?!
I've been calling web cam to get info on N/A setups with performance cams but still cant get info to look at. I was told that many tC's have been worked on. Does anyone here have cams from web cam?!!
Old May 14, 2008 | 09:52 PM
unxpectederror's Avatar
i dont really know of any cammed tc's other then the guy who was supercharged and got 310whp... i think they where pulling your chain. from what i know cams dont do much for this car
Old May 14, 2008 | 10:09 PM
ToyoCel's Avatar
i know the dont do much. im just wondering how much is not much. for some people 20whp is not much but for me that good. I need numbers or dynos. Someone here has to had some kind of cam work done to their NA set up.
Old May 14, 2008 | 11:45 PM
think more along the lines of like 10whp tuned with a piggy back
for most its not worth that hassles and money put into it
Old May 15, 2008 | 12:43 AM
ToyoCel's Avatar
what are you basing your info off of?
Old May 15, 2008 | 02:33 AM
silverstreaktc's Avatar
probably a guess and other motors with cams....just remember, we have an economy motor....it's not like you add cams and it unleahes the beast...well...no....
Old May 15, 2008 | 03:59 AM
ToyoCel's Avatar
yea your right but i believe my engines already a beast! Ive done a lot of mods to it already so changing the cams should be interesting. Well im not getting that many replies so im guessing no one has change there cams. I guess im going to do it and keep you posted.
Old May 15, 2008 | 04:20 AM
draxcaliber's Avatar
well, it is just that the cams are already pretty well designed from toyota to run on our n/a setup as it is.
rippmodds made a custom supercharger cam, but they claim it adds 15% more power with supporting mods. only person i know that has had it was icenine, and he had custom intake, supercharger, headera full exhaust, 12 psi pulley, water/meth injection, and tuning...i think with emanage, and he put down 311 whp.
so with the supercharger, a new cam unleashes 15% more power with supporting mods, which is probably all or most of those upgrades previously mentioned.
so if your doing an n/a cam, at most, you might get 15% with intake, header, exhaust, and tuning, since you won't increasing any psi without a supercharger, or injecting water/meth to cool it down.
and here is the link:
http://www.rippmods.com/category_s/255.htm
600, plus installation unless you can do it yourself or with our buddies.
this is icenines profile:
https://www.scionlife.com/profile/IceNine
i know that is all for supercharging, but there aren't alot of supercharged tC running those cams because of the cost.
oh, and i'm pretty sure that the cams for the 07-08 tC engine has a slightly more aggressive cam, so if you have an 05-06, you can look into ordering one of theres.
but that ripp mods camshaft is the only off the shelf cam that i know of, anything else would have to be custom.
Old May 15, 2008 | 05:27 AM
xCxHxRxIxSx's Avatar
^^ drax . would the 05 trd tune be able to run the 07 08 cams safely? because the slight change in them.
or will it just help performance
Old May 15, 2008 | 05:31 AM
if you changed the cams, you would need to tune.
Old May 15, 2008 | 05:35 AM
ahh ok . how bout those ripp mods im guessing i would need a tune for that too
Old May 15, 2008 | 05:39 AM
you would need a tune, and a helluva good shop to install it, replacing cams isn't a small install.
Old May 15, 2008 | 05:40 AM
maximthegreat's Avatar
^indeed
Old May 16, 2008 | 09:47 PM
ToyoCel's Avatar
well from the info i got from the peps at web cam. It would give me about 10 horsepower more if i do the regrind. Dont know about the price though... 600 bucks!!! thats 60 dollars per hp. The thing is no one has hard proof! Its all opinion. No one has done it and posted numbers yet.
Where did you get the info about the 05-06 cams being diff than 07-08? Was it from that rav 4 post? I called a dealer and some of the info on that was inaccurate. Plus theres only about a 3 to 4 hp difference which doesnt make sense when you take into account the cost of the job to swap out cams.
Old May 16, 2008 | 10:15 PM
they revised most of the engine for the 07-08 models. cams, pistons, intake and exhaust manifolds were all changed.
Old May 17, 2008 | 05:16 PM
ToyoCel's Avatar
OK THAT SOUND GOOD BUT WHERE DID YOU GET YOUR INFO FROM ... OR IS IT OPINION?
Old May 17, 2008 | 05:23 PM
07blackedouttc's Avatar
i have seen on a site that the 07 and 08 cams are slightly different than earlier models, they are more agrresive, thank you 07's
Old May 17, 2008 | 10:44 PM
if you use the thing called the SEARCH button you will see where i got it from
Old Jun 7, 2008 | 10:40 PM
ToyoCel's Avatar
06 07 dont even have that much of a power difference. its not enough of a gain to justify spending 500 - 1000 dollars on new cams and install. This is what i want to know. has anyone had their cams done by webcam on an n/a setup.... if so what kinds of gains did you get.
Old Jun 8, 2008 | 12:46 AM
the reason i was asking about installing the 07-08 cams was because the 07-08 supercharged tcs put down better numbers the cams being more agressive is part of the reason why .
