View Full Version : installing car speakers
Dkfung88
05-17-2008, 07:32 AM
So i've been looking around and i found these.....
http://cgi.ebay.com/6-6-5-Front-or-Rear-Speaker-Adapter-Scion-xA-xB-tC_W0QQitemZ310050770864QQihZ021QQcategoryZ50552QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
so im wondering if i really need these if i plan to take the stock speakers out and installing some alpine type r 6.5" speakers
yeldak
05-17-2008, 10:55 AM
you will need them, The stockers have the baffle built in, and they are riveted in place. I myself had a pair of these and honestly they are very cheaply made... I swapped mine for these:
http://www.edesignaudio.com/product_info.php?cPath=1_78_79&products_id=76
Just coated them really good with paint and clear to keep the moisture out of them
speed3jay
05-17-2008, 04:40 PM
I bought the ones from Elemental Designs as well. They're nice and cnc made but if you have the tools you should just make them yourself. Double check the mounting hole too because even though some component set and coaxials fit in there, my new Diamond Audio Hex components had a smaller mounting hole so I had to make another new baffles.
krazyqban352
05-17-2008, 05:01 PM
All you got to do is trace the stock speaker on to some mdf board and cut it out with a jig saw, it cose a whole $5 lol.
http://farm3.static.flickr.com/2289/2367945176_1a3c52f448.jpg
Yanki01
05-17-2008, 05:21 PM
made my own a good while back using a template a member had one here...
http://i22.photobucket.com/albums/b331/Yanki01/caraudio027.jpg
Dkfung88
05-17-2008, 09:19 PM
dude thats awesome.. yanki whats the dimensions of that board you cut out?
Yanki01
05-17-2008, 09:34 PM
**PDF file***
http://sweb.cincinnatistate.edu/mjmorris/audio/rearbaffel.pdf
Dkfung88
05-17-2008, 10:05 PM
awesome thanks dude!! what kind of wood did u use?
kidwolf908
05-18-2008, 12:27 AM
I bought the adapters that you listed from ebay and contrary to what has been previously said, I found them to be very high quality, sturdy, and a perfect fit. For $20, you cannot go wrong. I layered up some eDead on the front and back of them for additional cushion/seal and they worked perfectly.
Dont bother with the eD baffles, they're MDF which is easy enough to work with yourself. Either make your own, or go the route that you linked to.
