where are the synchros?
Old May 18, 2008 | 04:01 AM
07TCspec's Avatar
Default where are the synchros?
I know my synchros are bad on my TC. I want to know where the synchros are if I'm to upgrade my clutch fly wheel and get a short shifter would the synchros be part of any of these kits? maybe there is a synchros kit, also is it possible to switch the third gear since thats the one that's been grinding...If the synchros aren't gonna be part of any of those kits ill probably take it to the dealer for warranty services before adding the kits. I've got 4800k, 12k left on the warranty...I just want to know a little more about this before I go to the shop.
I found a link to d/l the shop manuals but didn't see anything labeled snchros maybe there just called something else?
Old May 18, 2008 | 04:51 AM
draxcaliber's Avatar
the synchros are inside your transmission, so they would be covered by your powertrain warranty. take it in to get fixed BEFORE you do a clutch or the short throw shifter.
and if you have 4800K, that would mean you ahve 4,800,000, which would have to be a record. you meant to say you have 48k.
so no, unless you want to overhaul your transmission yourself, take it to the dealership to be done.
and wow, you don't know squat about cars...why are you adding all these parts if you don't even know what they do and what they replace?
Old May 18, 2008 | 07:20 AM
07TCspec's Avatar
48k yea and I never said i knew anything which is why i asked and i never said i planed on doing this myself. i did say i wanted to know more info about this stuff before i go to the shop.
I understand my typing can be a bit confusing at times but don't add words I never said k tks ..The only usefull info i got out of you is "the synchros are inside your transmission" the rest is blah blah blah
Old May 18, 2008 | 10:19 AM
Foe's Avatar
Foe
How bad is the grinding?
I only ask because ive had little pop grinds (or so i thought) here and there, only to find out that what i was hearing is perfectly normal.......just ingagement
Old May 18, 2008 | 03:39 PM
07TCspec's Avatar
it's pretty bad but I can mostly control it If I double clutch.
someone told me to make sure I'm pushing the clutch in all the way. If i get up to say 25 mph push the clutch down to the floor than move to third with out giving gas it will grind, never did this before and stared around 45k. I drive alote 500+ miles for work and 200+ personal miles a week but recently iv been cutting back on the personal driving gas it getting outrages
Old May 18, 2008 | 03:46 PM
engifineer's Avatar
As mentioned, it requires disassembling the gearbox.
Old May 18, 2008 | 04:11 PM
Zebman's Avatar
Scion's warranty is 36k miles, correct? Umm, yeah.
Old May 18, 2008 | 04:43 PM
bumper to bumper warranty is 3 year, 36k miles, which ever comes first, that is true. but the power train warranty, as in the engine, transmision and drive shafts is 5 years or 60k miles, whichever comes first, so if there is a problem with his transmission, he is still covered.
a23r
Feb 1, 2016 04:05 AM
ffodge
Apr 25, 2015 07:03 PM
SanClementeXB2
30
Dec 28, 2009 10:08 PM
kanundrum
42
Sep 24, 2008 07:22 AM
SHiFTYxA
16
Jul 17, 2006 03:21 PM
