Rubbing QUESTION....PLEASE HELP!!!!
Old May 19, 2008 | 06:34 PM
Sharking4life's Avatar
Default Rubbing QUESTION....PLEASE HELP!!!!
I am getting a set of Rota D2's for my 06 tC, that has H&R race springs(about1.8" drop). I want to get 17x8.5. They wheels only come in a 35 or 48mm offset. I want to get the 35mm offset. Will they rub?...What size tires should I get with them?
Thanks
Old May 19, 2008 | 07:01 PM
PAUK's Avatar
u shouldn't rub....i have d2s and its 18x8 and im on coilovers...my front has no finger gap and i slightly rub on the wheel tub....so u should have no problem
Old May 20, 2008 | 03:56 PM
Leo_EdgeRacing's Avatar
18x8.5 ET 35 rubs on full locking turns with that kind of drop. Depending on what tire size you go with, you may not rub with the 17x8.5 ET 35.
Old May 21, 2008 | 04:43 AM
thanks guy...what tire would you go with if i go 17x7.5 with 35mm offset?
Old May 21, 2008 | 04:53 AM
AcidDrop's Avatar
you can still run the 17x8.5 with a 215/45/17 tire and you really shouldn't have a problem rubbing. yes the tires with stretch but it will should be fine if mounted propertly.
Old May 21, 2008 | 05:10 PM
I would run 225/45R17, but you can still run stock size 215/45R17.
Old May 22, 2008 | 05:49 AM
doper's Avatar
will i rub on o7 tc on 18x8 on teins?
Old May 22, 2008 | 06:37 AM
AcidDrop's Avatar
^what offset and tire size do you plan on getting.
Old May 22, 2008 | 03:43 PM
doper's Avatar
they are 18x8 Offset: 35 and tire 225/40/18
Old May 22, 2008 | 03:46 PM
AcidDrop's Avatar
with that offset you might want to go with a 215/40/18 tire, chances are you might rub with that offset.
Old May 22, 2008 | 03:52 PM
doper's Avatar
how bad will i rub cause the package come with those tires .
Old May 22, 2008 | 04:14 PM
AcidDrop's Avatar
^hmm i'll get back to you on this one in abit.
Old May 22, 2008 | 07:20 PM
18x8.5 ET 35 rubs on full lock turns on Tanabe DF210 (2" drop). You will be fine with 18x8 ET 35 and a 225/40R18 tire.
Rob54Monty
Jan 20, 2016 01:41 PM
terrye
Sep 26, 2015 12:24 AM
jtucker7
Apr 8, 2015 05:41 AM
meowtc
Mar 5, 2015 02:28 AM
Yakimaniac
Scion xD Wheel & Tire
Nov 22, 2014 04:20 PM
